Inspire HR not notifying me when I need to move and not vibrating
For some reason, my Fitbit HR is no loner giving me a notification I need to move if I am below my min. hourly steps (250) or vibrate if I make a goal.  This has started occurring within the last couple of weeks.
I have resynced my Fitbit to my phone and I have restarted my Fitbit.  Anyone else have this issue?
Moderator edit: clarified subject.
3 REPLIES 3
It's good to see you participating in the community @ulvdemon.
Thank you for providing the details about this situation with Inspire HR. I'm sorry to see that you are having difficulties with reminders to move.
Please confirm that you have restarted the device as suggested in this article.
Please try checking out that your device isn't in the Do not Disturb mode by long pressing the button.
I'd also recommend you to see this article: Why didn't my Fitbit device alert me?
Thank you for the response back.  I have attempted to restart the device by holding the power button, nothing occurs.  I've had to go through the settings menu to reset the device.  Also, long pressing the button does not show a Do not Disturb option, it just goes through to the settings menu.
After further checking, i have found out that the vibrating function is no longer working at all.  No alarm, no notifications, nothing.
I had same problem with Reminders to Move stopping. I enabled global Notifications and it started working again. Not sure if this cleared something else or if someone decided reminders to move should now be included if global notifications are disabled. Pretty sure I had notifications disabled for a while and reminders occured....
