02-29-2020
07:46
11:25
AlvaroFitbit
02-29-2020
07:46
11:25
AlvaroFitbit
The heart rate feature is no longer working on my Inspire HR. It stopped two days ago and resetting the device did not fix the problem.
03-01-2020
11:26
14:12
03-01-2020
11:26
14:12
@MrsMcNulty Welcome! It's great to see you around!
Let me help you with your Inspire HR not reading your heart rate and thank you for troubleshooting this issue. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
03-04-2020 05:49
03-04-2020 05:49
I tried 'chatting' with a fitbit representative who was no help. I ended up calling Fitbit and spoke with someone who insisted I had turned off the heart rate setting. I didn't even know how to get to settings. She was accusatory and mean.
I finally found the settings and turned heart rate back on, but again I NEVER TURNED IT OFF!
Not really pleased with this Fitbit and totally not happy with Fitbit 'tech support'.
07-05-2020 12:03
07-05-2020 12:03
I’ve completed all these steps that you provided the previous user and my device is still not reading my heart rate.
07-06-2020 04:52
07-06-2020 04:52
I’ve done all these steps also and
still no heart rate . Been a few weeks now and I’m over it !!
07-16-2020
05:42
14:12
07-16-2020
05:42
14:12
@Nellnell717 @CocoChanel22 I hope you're doing well!
Let me help you with your Inspire HR not reading your heart rate and thank you both for troubleshooting this issue.Since the issue persists I suggest you let our Support team know about this. @Nellnell717 I noticed that you already have a ticket so keep working with the team to find a solution.
@CocoChanel22 I have created a ticket so our Support team can further assist you via email.
07-17-2020 00:22
07-17-2020 00:22
I was having similar problems until recently after years using my Fitbit (this may seem stupid) but after weeks of fiddling I think that I was wearing my Fitbit too loose. I have lost quite a bit of weight but have never adjusted the strap!🙄 .. give it a try 👍
07-17-2020 16:42
07-17-2020 16:42
07-17-2020 16:46
07-17-2020 16:46
07-18-2020 21:31
07-18-2020 21:31
Hello, I have had the same problem. I bought the Inspire HR in February and had no issues until a few weeks ago. I have tried all suggest tips (several times), with no luck. How do I make contact with a tech to take a look?
07-19-2020 00:32
07-19-2020 00:32
I’m not sure TBH but despite my suggestions about adjusting the strap - my Fitbit heart rate Monitor Rate shows intermittently on the App - although it continues work correctly on my wrist .. I was hoping it would be corrected on the last update but the problem continues.. FITBIT must be aware I’m sure
07-19-2020 12:22
07-19-2020 12:22
Mine is not even intermittent. I've tried all of the suggested fixes. I even let the battery run out on it's own, cleared the data, and did (yet) another reset, with no luck. It looks as though many others have the same issue. I assume that FITBIT monitors this page and can give us users of their devices AND (for some of us), subscribers of their Premium services, a real fix or replacement of the product.
07-19-2020 12:26
07-19-2020 12:26
I wouldn’t hold your breath 🙄
07-19-2020 12:59
07-19-2020 12:59
Not encouraging @Smiffy59 😐
07-19-2020 18:21
07-19-2020 18:21
07-19-2020 18:25
07-19-2020 18:25
07-20-2020 12:22
07-20-2020 12:22
Hi Janell,
I went ahead and contacted the support department, who then referred my case to "higher level of support." I received an email from "Kevin" and was again advised to try several simple troubleshooting steps, none of which worked.
So I have now responded to their email that the fix attempts were unsuccessful.
I am now waiting a response. On the plus side I received the email response after my call within about 2 hours. We'll see what happens next...
-Alan
07-20-2020 12:30
07-20-2020 12:30
I went back for tech help via Fitbit Twitter DM .. to my surprise they replied within an hour and after a couple of attempts to fix we hopefully now have success!
In short I logged out of the app
then deleted the app
then re-set my iPhone
then re-loaded the app and logged back on
so far Good😊 - all seems ok 👍
though I have had previous false dawns!!🙏
07-21-2020 13:20
07-21-2020 13:20
07-21-2020 14:30
07-21-2020 14:30
I hope all goes well!
