01-15-2025
04:30
09:07
ManuFitbit
01-15-2025
04:30
09:07
ManuFitbit
Has anyone else experienced their Fitbit Inspire HR not recording sleep data? I’ve rebooted the device and the app. It has missed the last couple days. TIA
Moderator edit: clarified subject.
Best Answer01-15-2025 09:00
01-15-2025 09:00
Hi @vegget. Welcome to the community forums.
Thank you for providing the details regarding the difficulty that you are experiencing with your Inspire HR and the steps that you already done in order to fix it.
I would like you to double check that your Inspire HR is set to "On Wrist". This is because when your tracker is set to "On Clip" certain features are turned off including heart-rate tracking.
In addition, try to perform the following steps:
