Inspire HR not showing correct time
ANSWERED
The time on my HR is showing 8 hours ahead of the correct time. How can I correct this?
1 BEST ANSWER
Accepted Solutions
You can't manually set the time, but it should reset itself whenever it syncs to your phone based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
2 REPLIES 2
It's great to see you around, @Annie_Story and @SteveH, thanks for the input.
I was able to see here that our friend @SteveH provided some instructions in order to fix this timezone issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
