09-10-2019
07:51
09:34
AlvaroFitbit
09-10-2019
07:51
09:34
AlvaroFitbit
Everything has worked fine for the last two months, updates got installed within the last week and now my exercise menu doesnt work, it shows only run and pilates? (That i dont even have selected in the app and is the first time i see available), i dont know how it decided to uninstall the exercise options i can still see through the app, or why are they not showing when i synch the app with the fitbit. Please help! Thanks in advance!
09:38
09:31
09-11-2019
09:38
09:31
@Wildwuldwoman Welcome! It's nice to have you on board!
Let me help you with your Inspire Hr not showing your exercise options. Start by restarting it. After this retry adding the exercise on your Inspire HR and sync. If the issue persist then please remove the tracker by tapping the top left corner button then the tracker finally the trashcan icon to remove it. Set it up again following these instructions.
Let me know how it goes.
Best Answer12-29-2019 09:38
12-29-2019 09:38
Exactly same thing has happened to me, with the Run and all other options being Pilates. Hope yours turned out okay.
Best Answer06-16-2020 22:20
06-16-2020 22:20
Exactly same issue for me shows multiple Pilates but not other options anymore in exercise. Has anyone resolved?
06-24-2020
11:21
09:32
06-24-2020
11:21
09:32
@ellipete It's nice to have you on board!
Let me help you with your Inspire HR exercise options. You didn't mention any troubleshoots so I suggest you restart your tracker. After this remove the Pilates exercise option from your Inspire HR and see how it behaves.
