05-02-2019 13:49
05-02-2019 13:49
Hello,
I've had my Fitbit inspire hr for almost a week now and whilst setting it up initially, the press and hold of the side button brought up the quick settings list and showed the battery remaining.
Now press and hold of the side button does nothing except make the tracker vibrate one time and shows the clock face.
Can anyone tell me how to reactivate the quick settings and show the battery please?
Thanks
Best Answer05-02-2019 23:37
05-02-2019 23:37
Hi @FiFiMc Id suggeat you try restarting the Inspire several times. Hopefully that will fix the long press of the button. Please come back if you continue to have problems.
Helen | Western Australia
05-03-2019 00:13
05-03-2019 00:13
Thank you got the reply.
I have tried restarting several times, following the guide linked, but even that doesn't do anything. Long press still only brings on the clock face and vibrates the Fitbit one time.
Best Answer05-03-2019 01:43
05-03-2019 01:43
That is really weird! I will flag a moderator to assist you further.
05-03-2019 07:42 - edited 05-03-2019 07:44
Welcome on board @FiFiMc! Thanks for already troubleshooting this issue about the Quick Settings not showing up on your Inspire HR. Nice way to go!
Press the button, time/date show, hold the button and the battery and a small light bulb appears. If there is no line through the light bulb the Quick View is active.
Can you also please confirm you've restarted your Inspire HR by following the steps below?:
Thanks for you help @NellyG!
I'm looking forward to your response.
05-03-2019 07:46
05-03-2019 07:46
Thank you for this information, but as mentioned above, I have tried this and it does not restart the Fitbit.
Press and hold does nothing but display/turn off the time.
05-03-2019 09:59
05-03-2019 09:59
Hello @FiFiMc, thanks for coming back and for confirming you've tried the tips and recommendations provided here.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Please let us know if there's anything else we may do to assist in the meantime.
08-22-2019 04:30
08-22-2019 04:30
I am encountering the same problem, but I can't even get my device to restart! Please help 🙂
Best Answer08-22-2019 08:24
08-22-2019 08:24
Welcome to the Community Forums @SunsetRunner. Thanks for trying to restart your Inspire HR.
Since the restart didn't work, please check on the Fitbit app if your device is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Give this a go and let me know the outcome, I'll be around and glad to further assist you.
08-25-2019 15:42
08-25-2019 15:42
I just got my Inspire HR today and I had the same problem with the quick menu not showing up when I was holding the button.
The clock face I had it set to was “just time”, I changed the clock face to “simple stats” and it now works!
I prefer the other clock face so hopefully Fitbit will be able to fix this bug!
Also, is there a way to remove some of the features from the watch navigation? I would like to remove some of the things like water tracker and the weight tracker off of my watch since I don’t use those features?
Best Answer08-26-2019 09:33
08-26-2019 09:33
@meganmayers Welcome on board. I'm glad to hear that after switching to Simple Stats clock face, your device started working. ![]()
In regards to the apps you want to remove, please note that starter apps on some Fitbit devices can't be removed, including:
Alarms
Exercise
Water
Weight
Settings
Today
Weather
Let me know if there's anything else I may do to assist you with.
Best Answer05-15-2020 03:20
05-15-2020 03:20
I had the same problem as the OP. Pressing the button on the side had no effect, and the watch wouldn't/couldn't restart.
Changing the clock face however seemed to 'reset' the watch and now it is back to normal.
Was then able to return to my original clock face without issue.
Best Answer05-15-2020 03:56
05-15-2020 03:56
I seem to also be having this same problem. Just started this morning. I did sync up once, but it says it was 15 minutes ago. All I get is the clock face.as well, even after holding the button on the side.
Best Answer05-15-2020 04:05 - edited 05-15-2020 04:05
I am the OP, this still happens periodically to my inspire HR. But it corrects itself if I put it on charge until fully charged.
Best Answer05-15-2020 04:43
05-15-2020 04:43
I just tired restarting it...I didn't think it worked. I walked away to start working.. just came back to recheck & it seems to be okay now. I appreciate the reply.
Best Answer07-26-2020 06:42
07-26-2020 06:42
I’m having this exact same issue. Only have my Fitbit a couple of weeks. Did you find out how to sort it? TIA
Best Answer07-26-2020 06:43
07-26-2020 06:43
I’m having the same issue. Can you help please
Best Answer07-26-2020 06:46
07-26-2020 06:46
Hi Suzanne,
When it happens I always pop my Fitbit on charge until the smiley face appears and it resets itself.
Charging always fixes it.
Best Answer07-26-2020 14:41
07-26-2020 14:41
Best Answer07-26-2020 14:45
07-26-2020 14:45
Thanks for your reply but I've already tried that and it didn't work
