Inspire HR not showing the correct timezone
ANSWERED
2 days ago my Inspire HR changed time to +5 hrs. Right now is 8:20 am and my Fitbit says 1:20. I tried and went to my Dashboard and is on the right time zone (EST / Florida).
What can I do?
I checked on You tube and even though I turned it off and in it went back to same time.
Thanks!!!
Moderator Edit: Personal info removed and clarified subject for clarity
1 BEST ANSWER
Accepted Solutions
I also have the same problem since yesterday. I don't know what changed.
Tried all the solutions to date. Still not working correctly.
Reset the fitbit
Uninstalled and reinstalled the app
Checked time and location on android device
App set to:  ”use network provided time”
Disconnected (forget) Bluetooth device and reconnected
Fitbit was found
Attempted to resync using the app (Sync Now option)
App displays last sync time (as before this process started) and not immediate time
Fitbit time still wrong
Appears that Sync Now is not working on demand
6 REPLIES 6
Reset the fitbit
Fitbit was found
What is next step???? 🤔
Further update to the above:
The app is being updated with sleep stats from the Fitbit
App still displays last sync time (as before this process started) and not immediate time; app continues to display “Sync Now gathering your data”
This suggests that the Fitbit and app are connected but the last sync time and Fitbit time are not being updated
Summary of chat with Julian of Customer Support:
Having reviewed the above information he asked what devices we are using for the app.
Ans: Moto G5 Plus phone and Samsung Type A 10”’ tablet.
He stated that neither are on the list of their tested devices.
I stated that there are thousands of both in use.
I stated that for over a year my Fitbit and my not tested phone and tablet have synced. Something happened overnight on Thursday Dec 18 2020.
I have attempted all of the proposed solutions on this forum without success.
The recommendation from Julian is to obtain a device on their tested list!
Hi,
Thank you for your response. Do you know when is this going to get fixed?Thanks!
After speaking to a representative we performed the following:
(From memory of the call)
Turn Bluetooth off
Turn off location for the app
Reset the Fitbit
Turn on location for the app
Turn on Bluetooth
Connect to the Fitbit
In the app, “set up a device”
Choose your device
Select “replace”
Select your device
Enter the provided pin number
May take a while to configure
Device synced automatically
Time corrected!
Great job Lizetth
