11-17-2020
14:59
16:32
RicardoFitbit
11-17-2020
14:59
16:32
RicardoFitbit
My achievement app randomly stopped showing activity from the fitbit app. It says "no activity yet. Make sure the app has data or troubleshoot syncing issues". I disconnected and reconnected the two apps and it still shows the same thing. Does anyone have advice on how to sync them again?
11-17-2020
16:32
15:55
11-17-2020
16:32
15:55
Hi @Bcrawford22, welcome to the Community Forums.
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here. If you haven't already done so, I recommend you to check all the information that's specified on our help article: How do I connect my Fitbit account with another app? and then try the troubleshooting steps that are specified there.
Let me know if further assistance is needed.
11-19-2020 03:42
11-19-2020 03:42
I'm having the same problem. I noticed though when I look at 3rd party apps from Firbit that Achievement is not listed. Did Firbjf remove them from being a supported app maybe? I have the Charge 3.
11-19-2020 11:06
11-19-2020 11:06
I noticed that, as well. I havent been able to re-sync them since, so I'm assuming it's a hopeless cause at this point.
11-19-2020 11:06
11-19-2020 11:06
The link was not helpful for this issue, thanks for trying though.
