Inspire HR not syncing with MyFitnessPal
Inspire HR is not sending steps over to MyFitnessPal and has not synced with MyFitnessPal in a while.
3 REPLIES 3
It's great to see you around @JJGlenville.
If your Fitbit account isn't syncing with MFP, I recommend you to re-link the two accounts by doing the following:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
Let me know the outcome.
I'm having the same problem and have tried this but it's still not syncing....help!
Me too
