12-26-2024 13:23
12-26-2024 13:23
Just got off a support chat, but their solution is to clear my data off the Fitbit. I want to avoid this until I've tried absolutely everything. Any help is appreciated!
Can't sync my Inspire HR with my Samsung Galaxy A54 as of Monday evening (12/23/24, about 5 PM EST).
I've tried:
Nothing has worked, I'll swipe down from the top of the app and get an endless "syncing your data" message with the spinning circle. Syncing manually also doesn't work.
Plugging in the Fitbit and trying to add as a new device briefly syncs it enough to update the battery level, but it doesn't update anything else.
Earlier today, I got a Discord notification on the Fitbit, which is something that I've never set up before, but proves the phone is seeing the Fitbit and it should be syncing. Support didn't know why this happened.
Best Answer12-26-2024 14:39
12-26-2024 14:39
So, I installed an older version of the Fitbit app, and that synced my steps/distance from today, but nothing else. After this, I ended up updating to the current version and clearing the Fitbit's data, but now it's not connecting at all.
Best Answer12-27-2024 04:26
12-27-2024 04:26
please let me know if this works out for you, because I have the same issue
Best Answer12-30-2024 18:49
12-30-2024 18:49
No luck as of yet. I'm very salty because I'm missing out on my data transferring to Pokemon Go and Sleep...
