04-06-2021 07:13
04-06-2021 07:13
Hi,
Lately I have been having issues with sleep tracking. At least once a week my device does not log any sleep at all, and on other days it only records part of my sleep cycle. Last night for example it only logged 3 hours and 48 minutes while I slept for at least 7 hours.
I have tried restarting, resynching and tightening the wrist band, all to no avail.
Does anyone have a solution for this issue?
TIA
04-06-2021 09:19
04-06-2021 09:19
do you use the begin/end sleep feature on the phone app or just let fitbit detect you are sleeping. The begin/end sleep feature (which I used to use) does not give you detailed sleep data. It gave me detailed sleep data but not all the time.
04-06-2021 10:06
04-06-2021 10:06
I don't use the feature on the phone app, Fitbit detects when I am sleeping (or it should). I never used to have any issues with it but it has been malfunctioning lately and I have been unable to figure out why.
04-06-2021 10:18
04-06-2021 10:18
Yes it should work then, my problem is no one mentioned I shouldn't use the phone app. It seems to be a bit buggy feature. Export your sleep data what do you see?
I found this which helped me understand my problem:
'If you are not receiving sleep stages, I recommend considering the following:
This is a cut and paste so links might not work.
04-06-2021 10:33
04-06-2021 10:33
Thank you but this does not solve my issue. Like I mentioned earlier it was functioning fine before and has only recently started malfunctioning.
I have already tried tightening the band to ensure the device doesn't move but that has not solved the issue.
04-06-2021 12:50
04-06-2021 12:50
I have the same problem and tried the same solutions as you. Nothing has changed on my end, so I suspect this is a software issue and/or a way to get me to buy a new fitbit (which seems to have to happen every year).
04-06-2021 16:45
04-06-2021 16:45
My fitbit worked for a year but now since Jan 2020 does not give cycles... but does give restlessness and times awake... tried everything...
