05-28-2021
10:09
08:20
WilsonFitbit
05-28-2021
10:09
08:20
WilsonFitbit
No "do not disturb" icon on my device. Sleep has simply disappeared. As a night nurse, I follow my sleep pattern more than all the others.
I want it back.
Best Answer05-31-2021 08:13 - edited 05-31-2021 08:17
Hello @jayaitchdoubleu. Welcome to the community forums.
Thank you for the detailed information. If you haven't done so, I recommend performing a restart to your Fitbit device. In addition, please try to change the Sleep sensitivity setting. For example, if your sleep is now set to Normal, try to change it to Sensitive and test your Fitbit device. Take into consideration that normal mode can work well if you make significant movements like rolling over, your device records time spent awake. This setting is appropriate for most users. In sensitive mode, your device records nearly all movements as time spent restless or awake. This setting may be helpful if you wake up feeling tired even though your sleep history shows sufficient rest.
To change your sleep sensitivity setting:
I also recommend visiting the following link for tips and suggestions about Sleep: How do I track my sleep with my Fitbit device?
On a side note, I've moved your post to another board to keep our forums organized.
Hope this helps.
