09-25-2019 13:08
09-25-2019 13:08
Hi,
My wife's Inspire HR is consistently recording full sleep cycles while charging including REM. Considering that the charging sessions are an hour at the most I cannot see how this is not a bug as normally it requires a full 3 hours of sleep time to supposedly detect your sleep cycles.
This has to be an issue with the device or software, I am more inclined to the latter as I have seen so many people complain about the same thing.
Deleting the incorrect entry is not a solution and this needs to be addressed properly.
Thank you
09-26-2019
12:40
07:50
09-26-2019
12:40
07:50
It's great to see you around @PierreJoubert. Thanks for the details mentioned and the research done prior posting.
It's pretty weird that your tracker is recording sleep while you're charging it. I would like you to restart your Inspire HR and when you charge it check if it works normal.
09-27-2019 03:37
09-27-2019 03:37
I have restarted it multiple times and it still does it, even my ionic does the same thing on occasion.
Once I left my ionic on the bedside table overnight, not charging, and it recorded 12 hours of sleep with cycles... Nevermind that the sleep cycles it "recorded" made absolutely no sense whatsoever please tell me how this is physically possible?
09-28-2019 01:41
09-28-2019 01:41
Since the update that gives a sleep ‘score’, my Fitbit has twice recorded sleep sessions over 8 hours long. I knew, based on when I went to bed and got up, that this wasn’t possible - so I checked the details. The Fitbit recorded sleep start times of around 8:30pm - when I was either reading or watching tv. I subsequently went upstairs, took the Fitbit off to charge it whilst I had a bath, and finally went to bed. My resting heart rate is low, so I guess the device read my inactivity (reading or watching tv) as sleep - but I have only seen this error since the update, so wonder if an error has been introduced.
09-28-2019 05:16
09-28-2019 05:16
You make a good point we have seen an increase in issues since the sleep score introduction but we have been also experiencing this for some time before
10-01-2019
10:43
07:50
10-01-2019
10:43
07:50
Thanks for getting back @PierreJoubert. Sorry for the delayed reply.
Thanks for sharing your experience @Pony1961.
I would like you to perform a factory reset and then check if your Inspire HR doesn't track your sleep while its charging.
Let me know how it goes.
10-11-2019 16:50
10-11-2019 16:50
10-15-2019
09:48
07:50
10-15-2019
09:48
07:50
@PierreJoubert Thanks for confirming that you've tried a factory reset. Since, your wife is the one that's experiencing issues with her Inspire HR, I would recommend to let her know that she contacts our Support team, they will be happy to continue assisting her.
I'll be around if you have any additional questions!
10-15-2019 17:16
10-15-2019 17:16
10-18-2019
08:57
07:47
10-18-2019
08:57
07:47
@PierreJoubert Thanks for getting back. I appreciate your feedback and comments regarding your experience with Fitbit Ionic.
Sorry to hear that your Ionic is tracking sleep while you're charging it. In this case, I've shared your post with our Support team, they will continue assisting you and providing you with further options, keep an eye on your email inbox.
I'll be around if you have any additional question.
11-21-2019 00:13
11-21-2019 00:13
@SilviaFitbit For a while my Fitbit appeared to record relatively accurate sleep, but since I left it off the other night, it has gone haywire. It isn’t recognising any sleep before midnight. I’ve been going to bed around 10:30 and not lying awake for ages like I sometimes do - so I am pretty sure I got some sleep before midnight.
11-22-2019
08:19
15:07
11-22-2019
08:19
15:07
@Pony1961 Thanks for getting back.
Please change your sleep sensitivity to sensitive by doing the following:
Also, please restart your Inspire HR.
