05-15-2020
13:27
07:01
AlvaroFitbit
05-15-2020
13:27
07:01
AlvaroFitbit
I have an Inspire HR which I adore except for 1 thing - the alarm notification for the hourly steps warning. It either does not reliably do it every hour when needed or because it is just a vibration and I am so deep into whatever I am doing at the moment, that I miss it. Is there an program upgrade (sound) for the one I have, to change it or it there a different Fitbit that has more options.
Moderator edit: updated subject for clarity and removed all caps
Best Answer05-18-2020 07:53
05-18-2020 07:53
@MOBIRDMOM Welcome to the Fitbit Community! It's great to have you here! Sorry for the delay in my reply.
Let me help you with your Inspire HR reminders to move not working as it should. Reminders to move will activate if you haven't walked 250 steps for the specified hour if have already walked this then the tracker won't vibrated as you have already reached the hourly goal. You can try restarting your tracker by following these instructions. Also remove the reminders to move, save and sync then re-enable them.
Finally the tracker doesn't come with an speaker so it can make any noises but you can share your ideas on how to improve this feature in our Feature Suggestions board. Search for the idea first to see if one already exists so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes.
