10-01-2020 12:56
10-01-2020 12:56
Hiya, I read each night for a good three or four hours but my fitbit Inspire HR thinks that I am asleep and registers me as asleep. Then I do not sleep well and toss and turn all night but the fitbit does not seem to be registering this properly either. It is set for 8 hours sleep between 11pm and 7am, so I am not sure what is going on and how to fix this has anyone else had this problem and sorted it out? Thanks
10-01-2020 13:10
10-01-2020 13:10
Hi @StIves - When you sit still for so long, your device thinks you are sleeping. From a health perspective, it is better to get up and move around at least once an hour. But if you don’t want to do that, move your arm vigorously for a bit once in a while. Unfortunately, the tossing and turning may stop your Inspire HR from recognizing sleep. Bottom line - When your body is completely at rest and you haven’t moved for about an hour, your Fitbit device records that you’re asleep. You can read more about it here.
10-01-2020 13:10
10-01-2020 13:10
10-01-2020 13:14
10-01-2020 13:14
Thank you so much, I guessed this may be the case but wasn't sure. Thanks again.
