07-23-2020 19:17 - last edited on 06-21-2023 13:26 by DavideFitbit
Hi there!
It's been a couple of days that my Inspire HR screen is not scrolling or not responding to any actions on touching the screen. Only the side button works. I have tried to restart it and also to drain the battery completely, but nothing has helped.
Any ideas or recommendations?
Thank you
03-14-2022 10:01
03-14-2022 10:01
Hi there,
I’m having the same problem - my Fitbit Inspire HR screen is not scrolling, only the side button works. I have already restarted the device according to the instructions several times but nothing changed. What should I do?
Thank you,
M.
10-14-2022 04:11
10-14-2022 04:11
They replaced mine.
01-25-2023 05:50
01-25-2023 05:50
Hi LiliyaFitbit,
I'm currently having a similar issue with my HR Inspire: The side button works fine and I am able to scroll from the clock face up and down but only once. The scrolling then becomes very clunky and it is not as smooth as it used to be. I've already tried restarting and changed the clock face but no success. Any help would be appreciated.
Many thanks,
Beatriz
01-25-2023 10:26
01-25-2023 10:26
06-19-2023 15:34
06-19-2023 15:34
LillyaFitbit, my Inspire HR is doing the same thing. will not scroll, only the small numbers under the clock change. I have restarted it as recommended multiple times to no avail. I cannot scroll to get to the settings screen so I cannot reset it there. Please help! Purchased March 2, 2023
06-28-2023 09:52 - edited 06-28-2023 09:52
Hi Everyone.
In order to have the community better organized, I'll proceed to close this thread.
If you want to share ideas, have any inquiries or need help about other concerns please visit the community.
