Inspire HR screen not scrolling and battery not holding
Hi
my inspire HR screen has stopped working. I can see the main screen with my steps and time etc but it won’t let me scroll through or let me do anything. I have tried the reset a few times and when I do it still doesn’t work .
and now my battery only seems to be lasting a day ? It’s not even a year old yet .😕
10 REPLIES 10
@Emmaarn10 Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your Inspire HR screen not working and the battery holding a charge. and thank you for troubleshooting this issue. Since the issue persist the next steps is letting out Support team know about this. I noticed that you already have a ticket with them so keep working with the team to find a solution.
Let me know how it goes.
Alvaro | Community Moderator
Mine started doing this several weeks ago?  It had apparently died prematurely and I hadn’t noticed it in days. I charged it until it was 100% again and thought nothing of it. Then, I noticed it blinking every 1 - 1.5 seconds. Nothing I did, including turning on/off and resetting numerous times, made a difference. Totally unusable at this point. Please help, FitBit. You’re our only hope. 😜
  • Btw, my HR is 8-9 months old.
The flashing on my HR is draining the battery from 100% to 16% in exactly 6 hours. A single charge used to last almost a whole week before this started happening a few weeks ago.
I highly recommend contacting support. I explained the issue to a kind CSR who was able to verify that the last full battery charge lasted 16 mins. He is sending me a new device since it’s still under warranty. Thanks FitBit!
My battery only held a day tonite. Received it for Christmas 2019.
@SleepyMuse @GoedertTexas Welcome to the Fitbit Community! It's great to have you here!
@SleepyMuse happy to hear that our Support team was able to help you.
@GoedertTexas Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.You can follow these instructions to help improve the battery life.
Keep me posted.
All sorted now , it was still in the years warranty so they sent me out a new tracker 👍
Hey yes I did the same as mine was only 9months old and they have sent me a new tracker out 👍👍
Doing better. Thx!
Sent from Jo Goedert's iPhone
