06-05-2019 07:11
06-05-2019 07:11
Hi there, my fitbit inspire HR is one month old. The screen is coming on when I wake it and when I press the button and showing live and accurate information on the clock face however it will not scroll and I cannot bring up the menu by holding the button. it is still vibrating for alerts however the screen is completely frozen on the clock face screen. any help would be appreciated thanks
Best Answer06-05-2019 07:19
06-05-2019 07:22
06-05-2019 07:22
Thank you so much, I'll try this when im home from work as don't have the charger with me. Hopefully that will sort it! fingers crossed.
Best Answer10-17-2019 12:45
10-17-2019 12:45
Thanks, that worked!!!
02-04-2020 11:55
02-04-2020 11:55
How did you fix it
Best Answer02-04-2020 16:37
02-04-2020 16:37
To restart I attached it to the charger which was switched on, held the side button for about 10 seconds until you see a smiley face.
02-21-2020 09:13
02-21-2020 09:13
Worked - tho I had to hold for 20 seconds... But it DID work! Thanks!
Best Answer03-07-2020 03:39
03-07-2020 03:39
This worked for me, thanks!
Best Answer03-07-2020 10:35
03-07-2020 10:35
This worked for me thank you. I did have to hold button for longer and smiley face only appeared when I’d almost given up and left it !
Best Answer03-07-2020 15:01
03-07-2020 15:01
Success! Thank you.
