Inspire HR screen not scrolling
Hello my Fitbit stopped letting me scroll through all of the different devices it only shows the time and the number of steps I can’t even tell if the battery is charged or not I have not upgraded my iPhone 6 I haven’t done anything different it worked yesterday today it does not
6 REPLIES 6
@Puddin88 Welcome! Thanks for being part of our Community!
Let me help you with your unresponsive Inspire HR screen. Try restarting by doing the following:
  1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
  2. Hold the other end of the charging cable near the port on the back of the tracker until it attaches magnetically. The pins on the charging cable must connect securely with the port.
  3. Press and hold the button on your tracker for 5 seconds.
  4. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
Let me know how it goes.
Alvaro | Community Moderator
Hello thank you so much for answering my email however last night I felt the vibration on my wrist and looked at my Fitbit and everything was back so I didn’t actually have to do anything for some reason it just came back and it’s working fine today I will hold onto these instructions in case it ever happens again so thank you very much have a great day
Sent from my iPhone
@Puddin88 thank you for the update and sorry for the delay in mine.
Happy to hear that your tracker is working now and thank you for saving the instructions. Hopefully you won't need them but if you do they are quite easy to follow.
Happy stepping!
my Fitbit inspire hr has froze up 4 times in under 3 months use seems to be junk
I have the same issue. I tried a restart but it didn’t work.  My ap & device both show as up to date.  What is the next step?
My screen is frozen for about the 4th time in 6 months. Just tells time & date, will not scroll. Tried the Charger and 5 second jolt that you mentioned. Still frozen. Where do I go from here?
