03-31-2020 08:04
03-31-2020 08:04
GM everyone! Could anyone tell me why my screen isn't working? It was fine last night but today only the time shows; I can't do anything else from the watch. It's like it's frozen.
Thanks in advance:)
03-31-2020 09:22
03-31-2020 09:22
The same thing has happened to mine. It did not record my sleep last night and none of my steps today.
03-31-2020 11:11
03-31-2020 11:11
Mine has done that randomly over the past month or so - goes back to normal after a charge. But this morning, the screen is 100% blank, so I charged it and it’s still blank. I tried syncing to see if it’s recording, but the sync isn’t showing any steps today. Is my device broken?
03-31-2020 12:08
03-31-2020 12:08
I did a restart on mine and that worked. I plugged it into my laptop and then held the button on the side for 5 seconds, then let go, a smiley face came up and now it is working fine.
03-31-2020 13:18
03-31-2020 13:18
I’m glad it worked for you! Unfortunately, it’s not working for me. One short buzz when I hold down the button, but no screen response.
03-31-2020 14:19
03-31-2020 14:19
Getting the exact same response on mine.
Noticed the screen had went completly blank about 3pm today. Tried holding the power button for 5 seconds & simply get a short buzz, nothing else.
03-31-2020 14:35
03-31-2020 14:35
I went into the watch faces for the band & selected a different one from the standard / default one that's loaded on the unit when u 1st unpack it from the box.
Once it had downloaded & installed, the display has been fine / shown up when I've pressed the button.
03-31-2020 14:38
03-31-2020 14:38
Mine just buzzed as well and did nothing but I changed my clock face and it has been working since then. Hopefully that helps yours too!
03-31-2020 14:39
03-31-2020 14:39
yes! I tried that earlier today and it has been working since I changed my clock face! Thanks!
03-31-2020 19:44
03-31-2020 19:44
Thanks that works. Did the reset and got the smiley face and was good to go.
03-31-2020 23:15
03-31-2020 23:15
I swam with mine for the first time and then my screen just turned off. I tried charging it then while plugged held down the button for 5 seconds, nothing. Tried it again this time pressing for 15 seconds i got the smiley face but then nothing. HELP!
04-01-2020 06:10
04-01-2020 06:10
This happened to my daughters today for the first time (she has had it for not quite 2 months). She tried resetting it while it was connected to the wall charger and that did not work (per her). So I connected the USB to my computer and reset it there by holding the button down for 5 seconds (maybe a little longer). It showed a smiley face and now the swipe and touch are working normally again. Phew!
04-11-2020 10:28
04-11-2020 10:28
Did you ever get yours to work? I am having the same issue! I tried restarting multiple times and just changed clockface and no difference, still won't let me swipe. Thanks!
04-11-2020 11:44
04-11-2020 11:44
Yes. I hooked it up to computer to charge and while still hooked up I held button down more than once it took more than 5 sec. but got the smiley face and has worked ever since.
04-11-2020 12:32
04-11-2020 12:32
Thx for instruction to connect to computer and hold button 5 sec Worked for me too . Smiley face came on and now able swipe again
04-11-2020 14:50
04-11-2020 14:50
topped using my fitbit because It wouldn't charge so I recently bought a new charger, the same one it came with. I tried charging it with the new charger and it smiled at me, Now the screen is all black and won't work, it still vibrates though.
04-11-2020 14:55
04-11-2020 14:55
I am getting the smile but it isn't setting in, is your problem the same?
04-11-2020 15:22
04-11-2020 15:22
04-11-2020 18:10
04-11-2020 18:10
How did you change the clock face if you can’t get past the blank screen?
04-11-2020 18:28
04-11-2020 18:28
