06-12-2019
18:47
10:14
AlvaroFitbit
06-12-2019
18:47
10:14
AlvaroFitbit
When I press button or tap on the screen the time appears but cannot scroll to steps or any other info. The screen just goes blank.
Best Answer06-13-2019 10:15
06-13-2019 10:15
@kimberlyanncarr Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Inspire HR. Try restarting your device by following these instructions.
Let me know how it goes.
06-13-2019 10:15
06-13-2019 10:15
06-13-2019 12:44
06-13-2019 12:44
Before I saw your reply I had plugged it into the charger this morning and tried it again with no results, but when I tried again later it was fine. If the problem arises again I'll follow your recommendations. Thank you very much for taking the time to respond!
10-25-2019 13:49
10-25-2019 13:49
This has happened to me multiple times and I was wondering if this is common for the Inspire HR or if there is something wrong with mine.
02-06-2020 00:54
02-06-2020 00:54
Thank you, your advice worked and my fitfit is working perfectly.
Best Answer02-13-2020 06:09
02-13-2020 06:09
Thank you for the link to the reset instructions. However, this needs to be something you can do without the charger! A long press on the button should be able to initiate this; not everyone carries their fitbit charger around 24/7 (why would you?!?) and now I'm at work for the next 10 hours with a fitbit that is not tracking anything. Please forward to development.
02-17-2020
11:38
06:31
02-17-2020
11:38
06:31
@CoriW A warm welcome to our Community! Sorry for the delay in my reply.
Thank you for your inquiry. Currently this isn't available but you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exists so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Best Answer02-17-2020 15:44
02-17-2020 15:44
I tried resetting as instructed but it has not worked. Now what?
03-10-2020 14:54
03-10-2020 14:54
You say turn off.. But how do i do that??
19:11
08:52
AlvaroFitbit
03-20-2020
19:11
08:52
AlvaroFitbit
would not show charge wouldent scroll threw hit the button nothing.
I changed my clock screen from phone app. It works fine again.
Moderator Edit: Formatting
06-14-2020 03:40
06-14-2020 03:40
Thanks man, this worked perfectly and restored my Fitbit Inspire HR's operation. Much easier than tracking down a charger and restarting. Kudos.
06-14-2020 13:02 - edited 06-14-2020 13:03
No problem I'm happy it worked for you. I have had to do it couple times now. so happy I figured it out I was in try everything mode. I haven't seen my fix any where online. So share away. Happy stepping.
07-07-2020 20:09
07-07-2020 20:09
This worked perfectly! Thank you!!
08-28-2020 08:51 - edited 08-28-2020 08:52
I had my Inspire HR lock up, stuck on time display, (clock still working)
Not running it from Smart Phone, using PC.
Went to the PC App Dashboard, and selected Account (Icon top right on screen) and from there selected "Activity" & (I think) clicked on on of the settings without changing it , which unfroze the touch-control on the watch. Not entirely sure about what happened when but the standard method quoted by Fitbit didn't work for me (repeatedly!!!), and I have had previous issues of this type with the watch.
Inspired to do this by the post about changing the clock-face using the Smart Phone app, so thanks for that!
