09-01-2019
15:16
08:20
JuanJoFitbit
09-01-2019
15:16
08:20
JuanJoFitbit
I have had my Inspire HR for a 4 months now but it has in the last day just stuck on the clock screen. I can’t scroll. It charges ok. I’ve tried resetting several times but this makes no difference, any advice as to how I can resolve this problem. Thanks.
07-18-2020 13:35
07-18-2020 13:35
07-18-2020 14:08
07-18-2020 14:08
07-18-2020 16:19
07-18-2020 16:19
08-06-2020 15:20
08-06-2020 15:20
I am having the same issue with my Inspire HR which is just a few months old. Started two days ago. I have tried resetting it repeatedly but it won't reset. Please help us all resolve the issue, Fitbit.
08-06-2020 16:49
08-06-2020 16:49
08-20-2020 13:37
08-20-2020 13:37
My Inspire HR is only 8 months old and I have had the same problem, screen won’t scroll, even after trying the suggested fixes. Previously over the last few days the screen is also lighting up randomly, which drains the battery within a couple of hours. I have switched off the option for the screen to light when you turn your wrist but that didn’t help.
Any help would be appreciated.
08-20-2020 14:25
08-20-2020 14:25
08-20-2020 22:44
08-20-2020 22:44
Yes, I’m not sure what else I can do now - very frustrating!
03-30-2021 14:02
03-30-2021 14:02
What did you end up having to do yo fix it? Mine is doing it too. Thanks!
03-30-2021 14:03
03-30-2021 14:03
Can you please get a moderator to help me too with this same problem? Thank you!
03-30-2021 14:13
03-30-2021 14:13
03-31-2021 23:28
03-31-2021 23:28
04-01-2021 07:06
04-01-2021 07:06
04-01-2021 07:51
04-01-2021 07:51
06-25-2022 13:55
06-25-2022 13:55
Awesome, it worked. You are a star and I will always remember this. Kind regards.
