11-18-2020
14:35
05:39
11-18-2020
14:35
05:39
My fitbit Inspire HR, which I wear all the time, including the shower, has stopped working. The green light still works but the screen will not turn on. Looks like there is water under the screen. Any ideas to help?
Best Answer11-18-2020 19:36
11-18-2020 19:36
Hi @Xopherblue put the pebble piece into a dry bowl of rice to draw out the moisture. Don't charge it until it's been in the rice for a few days. Then clean it up, especially the contact points and restart it while on the charger. See if it helps. Most of us charge our devices while showering, so it might be a good habit for you to get into, too.
