02-25-2020 19:39
02-25-2020 19:39
Hi there! I have an Inspire HR and am seeing that my logged exercises for today (treadmill and weightlifting) shows that I burned 0 calories during both exercises. I was wearing my Fitbit while at the gym but I always manually log my activities and have never had an issue with the app displaying 0 calories burned for a particular logged activity until now. When I click into the exercise that has been logged, it says “not enough data available” under calories burned. Anyone know why this could be happening?
Best Answer02-25-2020 19:41
02-25-2020 19:41
I just posted something very similar! My issue is because the logged exercises are on a different time that when it actually occurred. I wonder if it’s a widespread issue they are currently having?
Best Answer02-25-2020 22:29
02-25-2020 22:29
I had the same thing happen tonight. I always log my cycle rides at the gym and today I didn’t get any data - same message that not enough details. I checked to make sure HR was on and it is.
Best Answer02-26-2020 16:00
02-26-2020 16:00
To follow up, same thing happened to me today, 0 calories burned during my logged exercises and “not enough data”.
Meanwhile, I woke up this morning to an unusually high amount of calories burned for the day already, so I checked the app and it shows a high amount of calories burned in the ~1 hour after midnight. It’s as if my calories that were supposed to be accounted for from my logged exercise yesterday weren’t measured until midnight.
I’m also noticing that my logged exercises from earlier in the week show that they occurred at different times than I originally recorded them, i.e. I recorded a treadmill activity for 4pm and it now is showing that it occurred at 10am, when this was not the time I entered and not the time the activity occurred.
It seems like there’s a system glitch having to do with time?
Best Answer02-26-2020 16:28
02-26-2020 16:28
If you look at my message from earlier today - I'm having a similar, yet different issue. There's got to be something wrong with the exercise area. So hopefully they will investigate all these things.
Best Answer02-26-2020 18:48
02-26-2020 18:48
Okay - I did a little investigating. In case nobody responds from Fitbit officially. I think mine was tied to the fact that while I had the app on my phone set up to record my exercise, my actual Fitbit Inspire HR watch was set to detect activity. So maybe the two were fighting for superiority? I went to the app and turned off all of the "auto recognized exercises". Tomorrow will be the true test.
Best Answer02-26-2020 19:03
02-26-2020 19:03
It’s worth a try! It just seems odd that on my end I’ve been logging my exercise manually this whole time, especially because I do a lot of weightlifting that is not step-based, and it seems to have not had a problem to generating calories burned etc for the exercises I log, up until the past 2 days.
Let me know if your method works!
02-26-2020 19:53
02-26-2020 19:53
Funny that you mention that... I noticed the same thing today! It’s showing high intensity calorie burn right after midnight for me. It did show up that my HR was 46 during my cycle class.
I also logged my POP Pilates class today & yep, the not enough data with no HR shows up.
of course my calories are way off for today with the night number being early morning when I was sleeping.
Best Answer02-26-2020 19:54
02-26-2020 19:54
I’ll try that too - let us k ow what you find out & I’ll do the same! 😉
Best Answer02-26-2020 20:07
02-26-2020 20:07
Well, mine worked fine on Monday and then Tuesday and Wednesday were a mess. Fingers crossed!
Best Answer02-26-2020 21:39
02-26-2020 21:39
Same here! If it is still wonky tomorrow then it has to be a system glitch - especially since we are having the same issues, same time frames and so forth. Hopefully we’ll get it figured out sooner rather than later!
Best Answer02-26-2020 22:06
02-26-2020 22:06
Best Answer02-27-2020 13:34
02-27-2020 13:34
My experiment didn't work. Now, instead of having all those individual workouts, plus the one with 0 calories and "not enough data available" - I only have the zero calories and "not enough data available". Fitbit has to know this is a problem.
Best Answer02-27-2020 13:35
02-27-2020 13:35
I contacted support and they let me know they are aware of the issue. Hopefully we will have a fix soon!
02-27-2020 13:39 - edited 02-27-2020 13:40
You got someone in support more informed than I did when I called yesterday 😉
I saw a comment about a fix that involved disconnecting the Fitbit, deleting the app, deleting the data on the device and re-installing but that's a whole lot of work on my part to fix an issue that if affecting so many users and that we are not responsible for. I'm holding out for a better solution.
Best Answer02-27-2020 13:42
02-27-2020 13:42
I tried that and it didn’t work 😞
Best Answer02-27-2020 13:44
02-27-2020 13:44
@AlexaGcole - These were the exact instructions from the other post, is this what you did?
Un-installing Fitbit app from the iPhone
Turning the iPhone off and then back on
Removing all user data from the Inspire HR
Re-installing the Fitbit app
Setting up the Inspire HR while it is connected to its charger and charging.
Having it connected to the charger seems to be key.
Best Answer02-27-2020 13:52
02-27-2020 13:52
I did all of that, minus the turning my phone off and on again. I'm on a "chat" with customer service right now.
Best Answer02-28-2020 21:22
02-28-2020 21:22
I didn’t end up logging a workout yesterday but did this morning. Same thing - no HR and the message of not enough data. However, the app seems to be double counting calories as it shows intense calorie burn around noon (my cycle class was at 5:30am) it also gives a low HR at 68 for 3 min during the early morning.
I haven’t had a chance to contact support but will try over the next few days. 😕 It’s just a bummer since all was working fine until Tues night & the calories are overstated since then if I log an workout. I haven’t cleared any data but did restart my fitbit twice. I did notice thought that before I synced, my fitbit seemed to be more accurate in calorie burn & the app on my phone added more.
Best Answer02-28-2020 21:35 - edited 02-28-2020 21:35
Has anyone gotten this resolved yet? I'm still getting the "Not Enough Data Available" message 😞
