Inspire HR shows a "001 error" message
ANSWERED
I have an inspire hr.  I got a low battery indication, and a little while later the screen changed to the Fitbit logo, with the numbers 001 and IKQMHJJ3.
I plugged the device in and left it for a while but there was no change.
I tried restarting it by holding the button in while it was plugged in button in for 10 seconds. After that the screen went black and I released the button. It showed a smiley face, then a black screen and wouldn't respond. A short while later the 001 error was back.
223 REPLIES 223
The same thing happened to mine today but i got it fixed by just re-syncing it using the app. Hope that helps.
My Inspire is 3 months old.  It will only show time.  I have tried restarting numerous times with no luck.
Woke up.to the same problem.  I'll be calling the customer care line this morning. Super disappointed in the product. Hope to get some resolution today.
Purchased on 8/7 from Amazon.
Warranties till 9/7 for return.
Dead on 10/7.
Ain't that something?
I plugged in the cord to my computer, attached the fitbit to the end, pushed the power button for like 8 seconds and then one more time and VOILA! It's now back on.
Hope everyone else finds as fast and easy a fix I it looks like it did.
Moderator edit: merged reply
I haven't tried plugging into my computer! Will give that a shot when I get home tonight! Super jazzed. I hope it works!
Get Outlook for Android
I got my replacement Inspire 3 weeks ago. Now this one is also stuck on the time only. Cannot change the display on my Inspire. Hasn’t synced with phone in 2 days. **ahem** PRODUCT
Fingers crossed!! 🤞
Screen has gone blank completely, looks like a common issue how do I get this fixed?
Have already tried resetting lots of times and changing clock face nothing works so is faulty
'/\_/\'
**JOY**
(__(_______)
FitBit sent me a new Inspire, after 3 weeks it went blank too. It is not an iOS13 issue it is with FitBit Inspire.
Thanks FitBit, now you are editing my posts.
Same problem here. It was working fine earlier in the day then, while I was on a flight, it went blank. I feel it vibrate when I try to reset and even though blank it continued to track and sync with my phone, but nothing I do gets the display back.
It seems to be a known issue. I ended up taking mine back to the place of purchase and the replaced it for free as it was only a couple of weeks old. Wasn’t going to bother sending it back to Fitbit for them to take 3 weeks+ To repair it and be without it during that time 🙂
I'm  having the same issue as Dave. Had my fitbit since April n this has never happened before. I tried the reset process n nothing but a smiley face then blank. I even had the 001 error message
Hoping i can get some help
Ah, the dreaded Black Screen!  I have the same problem here - HR Inspire was bought in April this year (2019) There were a couple of minor glips but I managed to sort them out fairly quickly.
Today, however, the screen suddenly went totally blank. I put it to charge, although I knew that it should still have about 60-70% battery left - but no improvement.
I can't even raise the smiley face, or an error message, although the Fitbit itself does vibrate when I press the button.
Bizarrely, the iPhone app is till working, and is actually syncing much more quickly than it has been doing of late (which has been pathetically slow) - just nothing at all happening with the device itself, alhtough app now says battery is 99%. Anything to try? - or just take it back to the shop?
Reach out to Fitbit Customer service... they will walk you through it. If
it doesn't work and is still under warranty, they will replace it for you!
They are awesome!
L. Canizalez
Thanks, but how do I contact them, please? And how quickly will I get a reply, so you think?
Blackcat 99
Go to Fitbit.Com, scroll all the way down and click about us. The next
page will give you a "contact us" selection. Next page, scroll down to
bottom "customer support." Next page, scroll down and click button inner
"let's talk." It will be faster if you utilize live chat with them. Good
luck
L. Canizalez
Thanks for that info, Lcanizalez73
Even more bizarrely than the way it stopped working, the display on my Inspire HR has suddenly started to work again - without me doing anything to make it so.  I had put it on my wrist earlier, to see if it would work, and it didn't, but I didn't get around to taking it off again. Just looked at it just now, and it suddenly flashed into life - and has actually managed to count in the additional steps which I've taken while wearing it, while the display was out of action. Weird!
I'm a little bit apprehensive that this may happen again, and, since I have no idea what the problem was, or how it got cured, I probably won't rely on it too much in future.  I'll hang onto the information which you gave me, ready to use if required.
Thanks again, Blackcat99
Have had inspire her for a year without an issue.  Today screen went blank.  Can’t reset. It is charged to 99% but can’t get anything on the screen.  No smiley face with reset.  Vibrates for a second every couple of seconds.  Help
I don't know how to tell you this, but it's time to contact Fitbit customer service.  I'm on my fifth Inspire HR, and every time it got to that constant vibration, it was dead, with no way back.  Every. Time.  Without exception.
