09-03-2020
12:29
05:20
JuanJoFitbit
09-03-2020
12:29
05:20
JuanJoFitbit
I am getting a message on FB "Check Charger. Battery not charging."
I cleaned my FB and the charger. I bought a new charger and got the same message. Can't restart due to FB not recognizing the charger! Help!!
07-07-2021 13:39
07-07-2021 13:39
Update again: Same issues continue with replacement with error charging message. Happened four times at the beach. Yes I could push the reset button and it eventually goes away. I am so disappointed with Fitbit. Look at the specs for Charge 4….says environmental conditions up to 140 degrees!!!! Really?? Thinking about getting a refund. Thought about the new Lux but it’s good for only 113 degrees.
07-09-2021 18:00
07-09-2021 18:00
I get the same thing
07-09-2021 18:52
07-09-2021 18:52
For everybody that has the same problem, try to buy a new charger on Amazon or Fitbit accessories store. If the problem persists, you will need probably need to change the battery unit or the charging pins (malfunctioning charging pins are a common problem on Fitbit HR and Inspire 2). To change it, go find a repair store that use genuine Fitbit parts for more reliability and customer service.
07-09-2021 18:56
07-09-2021 18:56
07-09-2021 19:22
07-09-2021 19:22
@RBDK97 There is no genuine Fitbit parts repair store. There are no batteries or parts available from Fitbit to repair these devices. Anything someone does could invalidate their warranty, should they still have one. Fitbit doesn't warranty anything unless it's purchased from an authorized retailer, and it would be the entire unit, the pebble, band and charger.
08-01-2021 08:21
08-01-2021 08:21
Do you like the Amazfit? I’m getting the check charger error as well.
08-01-2021 08:22
08-01-2021 08:22
Did you get a resolution? Mine is doing the same as yours.
08-12-2021 16:48
08-12-2021 16:48
Wow same thing happened to me today. I was out in the hot sun and it was going haywire, every few minutes it would give me that message that it wasn’t charging even though it was on my wrist. The battery was at 90% too, did you ever find out why it did that?
08-12-2021 17:05
08-12-2021 17:05
08-12-2021 17:40
08-12-2021 17:40
08-13-2021 07:13
08-13-2021 07:13
Yes… just pressing the side button will clear it. Even in the pool it shows message.
Continued issues with the message even with the replacement. I requested a refund and was granted a 50% off a new device. Ordered the Versa 3. Should arrive today. They admitted it was a software issue. Venture on warriors. Stick to you guns. It is a faulty device.
12-27-2021 12:17
12-27-2021 12:17
Thank you for this info. I live jn FL & have used my FB outside all summer - heat & humidity. It’s acting up now, in cool weather. Happened twice today & it tells me the battery is low when it’s not. 😤 Pushing the side button is useless. Curious how you like the Versa 3.
12-27-2021 12:30
12-27-2021 12:30
08-01-2022 01:20
08-01-2022 01:20
Same problem here but I note that you don’t appear to have received an explanation.
I was hoping that I wouldn’t have to contact the help desk after reading your enquiry.
08-01-2022 07:04
08-01-2022 07:04
08-01-2022 07:46
08-01-2022 07:46
08-01-2022 12:37
08-01-2022 12:37
08-02-2022 00:30
08-02-2022 00:30
