07-11-2019
08:35
09:08
YojanaFitbit
07-11-2019
08:35
09:08
YojanaFitbit
Inspire HR stopped syncing with app. Bluetooth is not pairing with device after update yesterday@ 9:37am. Tried all troubleshooting Technics suggested in help pages. Still no pairing. The update definitely messed up
Best Answer12-22-2020 19:38
12-22-2020 19:38
Old thread but I came upon on it when my iconic and inspire hr each had problems. I hate these things, but need it for insurance purposes. Just figured out the syncing issue with my HR. It wouldn't work.to fix; In the app on your phone: go to account... Account settings... Authorized devices. REVOKE ALL.
I i had to re-sign into the app on my phone and it synced on its own immediately. Hope this helps.
Best Answer02-24-2021 02:28
02-24-2021 02:28
Your listed instruction are rather confusing. For example, in Step 1 you say to turn off the phone. Then in Step 2 your instruct to go to the account. Would you take a look at these steps and clarify, please? Thanks.
06-10-2021 12:16
06-10-2021 12:16
I am having the same problem. Directions to resolve are so confusing. MUST TRACK FOR INSURANCE. Very frustrating
06-10-2021 14:17
06-10-2021 14:17
I may have to consider this. My fitbit unhooks often and now I have no device recognized on my phone app and it doesn't "see" the FitBit. It's basically a pedometer and watch for me now. Ugh.... It's only two years old. I'm not buying another one.
Best Answer02-26-2022 20:41
02-26-2022 20:41
I have been having syncing issues with my Inspire HR the last 2 days. Coincidentally, the same 2 days I forgot to remove it before I showered.
Thank you! Right after the happy face appeared on my Inspire HR, it synced with my phone.
03-11-2022 11:50
03-11-2022 11:50
Having the same problem after using it for 2 years! Have tried everything, when I re-setup device it gives me code and goes no further. Reset phone, app, Bluetooth, not sure what else to do
Best Answer03-13-2022 12:50
03-13-2022 12:50
Fitbit have resolved and were very helpful. They got back to me straight away, I had tried resetting everything on my phone. What I actually needed to do was go to settings on my watch and reset it. I then added device from scratch in app and it worked.
Best Answer04-21-2022 08:29
04-21-2022 08:29
Worked for me today. Seems to lose most of data. Now got all data needed
Best Answer05-17-2022 20:07
05-17-2022 20:07
Thank you. This really worked after trying multiple ways before this.
Best Answer07-14-2022 06:00
07-14-2022 06:00
I am having trouble again with inspire hr. I have got to the point of deleting device from app, every time I try to resetup device, it detects but unable to pair with code. It is not under Bluetooth on my phone. I have tried reinstalling app, rebooting watch, restarting phone. Stopping app and logging out of app. Please help!!
Best Answer07-30-2022 12:27
07-30-2022 12:27
I'm having the exact same problem.
Best Answer07-30-2022 14:36
07-30-2022 14:36
I did everything I possibly could except factory reset. Support advised me to do this and it worked, when I re-added device after a few mins it detected it.
Best Answer08-07-2022 05:33
08-07-2022 05:33
When you did the factory reset did you lose all of your data though? Mine hasn't synced for 7 days, and here I am awake at 12:32 am trying every single thing that has been suggested because I really need my sleep data from this last week!
Best Answer08-07-2022 05:41
08-07-2022 05:41
Best Answer08-07-2022 23:16
08-07-2022 23:16
Thanks. After 7 days of me trying everything in the advice section to try to sync it, mine magically synced itself while I was finally asleep last night, so at least I have my data - not sure how accurate it is, because I can't remember what times I went to bed and woke each night. I wonder when it will next sync.
Nothing more annoying than seeing that "You should wear your fitbit to bed" message repeatedly when I am desperately trying to sync it to get my sleep data.
Best Answer08-08-2022 00:06
08-08-2022 00:06
