09-17-2021
		12:03
		08:30
			SilviaFitbit
		09-17-2021
		12:03
		08:30
			SilviaFitbit
My HR monitor has stopped working. Grey heart shape with two dashes underneath.
 Best Answer09-17-2021 12:38
09-17-2021 12:38
Sorted it. I linked my phone app to a new device, a 4 digit code came up on my existing device, I followed the instructions and the HR monitor is back. 😀
 Best Answer09-18-2021 08:37
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              09-18-2021 08:37
@Grimsbyjackie Welcome to the Fitbit Community. Thanks for the details mentioned.
I moved your post to this board, in an effort to keep the forums organized.
Glad to hear that once you paired it to your phone, the heart rate started working. For future references, I'd like you to make sure heart rate is turned on in the Settings app on your tracker. Next, make sure you're wearing it correctly, either by moving it higher or lower on your wrist or by tightening or loosening the band. Inspire HR should be in contact with your skin. After holding your arm still and straight for a short time, you should see your heart rate again.
Hope this helps.
