01-21-2021
16:02
03:29
JuanJoFitbit
01-21-2021
16:02
03:29
JuanJoFitbit
Recently, around 1 in 3 or 4 chances, the app exit running mode when I was running, stopped recording .. however, sometimes it works perfect, record everything. I bought this last March, not sure if this one is broken, needs a new one, but I heard it has at least 1.5 years to work properly.
Best Answer01-23-2021 03:28
01-23-2021 03:28
Hi @Cathy2020, it's great to see you in our Fitbit Community. Since you mentioned that your Inspire HR exits from the running mode, I'd like you to restart it as described in this help article. After this, check out this help page, which explains how your Fitbit device tracks your workouts.
Finally, monitor your Inspire HR and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer01-23-2021 19:45
01-23-2021 19:45
Hi JuanJo,
Thanks for the advice, I restarted the device, and will see if it works fine every time I run.
Best Answer01-25-2021 10:05
01-25-2021 10:05
Hi @Cathy2020, you are welcome. Please don't hesitate to get back if more assistance is needed and I'll be happy to follow up.
See you around.
