04-27-2019 12:31
04-27-2019 12:31
I started the firmware update about 30 minutes ago and it seems to be stuck...no progress. Is there anyway to stop it or start over?
04-27-2019 18:40
04-27-2019 18:40
Hi @Slvrpdle Id suggest you try restarting the Inspire a few times and then will hopefully be able to try updating again. Please come back if you continue to have problems.
Helen | Western Australia
04-28-2019 09:34
04-28-2019 09:34
It is not stuck but rather takes an abnormally long time to update depending on your phone.
I'd give it at least an hour.
Mine took about over 30 minutes.
05-10-2019 17:28
05-10-2019 17:28
Hi
Mine took an hour and six minutes. Very misleading too, as the first page says you can go away and do other things whilst it updates, then when you click next, it tells you to hang fire and keep the page open whilst it does the update! Which should only take 10 minutes. Not impressed.
07-15-2019 17:01
07-15-2019 17:01
My Update (07.14.2019) took 1 hour 24 minutes. And yes, the screen on my Samsung S7 said that it may take as long as 30 minutes. So much for exceeding expectations 😉
However, it is worth noting that I had to restart my phone, reset my watch and cycle BT and wait for the normal Sync to occur Before the update would begin.
07-16-2019 15:53
07-16-2019 15:53
My Fitbit has been stuck for 3 hours. I’ll will try some of your suggestions. Thanks everyone.
09-04-2019 09:38
09-04-2019 09:38
Should I be able to see anything on the screen during a firmware update?
Just got my HR in today and it's been "installing" for over an hour, and nothing shows on the display.
01-05-2020 06:59
01-05-2020 06:59
I got my son an inspire HR for Christmas and have been trying to do the software update and set it up but it seems to be stuck and showing no progress at all.
01-11-2020 15:13
01-11-2020 15:13
I am having the same problem. It has been "updating" for two days now. Did you ever get yours to work? I want my Alta HR back!!!!!
01-11-2020 15:27
01-11-2020 15:27
01-11-2020 15:36
01-11-2020 15:36
Hi. Yes I did. I can’t remember exactly what I did since it was several months ago, but it’s been fine with no issues with other updates.
I did a lot of research to find the answer.
I may have deleted the app and re-installed it. I also think I held the button down on the side of the Fitbit for about 30 seconds.
Sorry I can’t be of more help. Whatever I did, it worked and I haven’t had a problem since.
Sent from my iPhone
01-11-2020 15:44
01-11-2020 15:44
01-11-2020 15:47
01-11-2020 15:47
01-11-2020 15:47
01-11-2020 15:47
Button - not bottom 🙂
