07-07-2020 14:34
07-07-2020 14:34
I wanted to buy the Fit bit Inspire HR watch and when I tried the small one on it was too big for my wrist, I have a really small wrist, it is 5 inches in circumferences. Any solutions?
Thank you!
Best Answer07-07-2020 17:34
07-07-2020 17:34
One possibility: Amazon sells very reasonably prices third-party bands for all Fitbits. It's worth a look to see if any specify being extra-small.
Another possibility might be to punch your own holes in the band at smaller size. I have no idea how well that would work or if the new holes might rip right through. And that would negate Fitbit warranty on the strap.
07-07-2020 17:35
07-07-2020 17:35
Hi @Lujain16 the answer might be to get the Inspire (doesn't have HR) which can be used with an optional clip. The clip can be put on a pocket, waistband or whatever place you find comfortable. The other thing would be to see if there are any third party bands which are made for the smaller wrists.
07-12-2020 18:48
07-12-2020 18:48
Thank you @JohnnyRow I ended up buying the Versa Lite and the strap fits me perfectly. Turns out that the first salesperson at best buy gave me the large strap and told me that it was the smallest, I'm glad I went again.
07-12-2020 20:22
07-12-2020 20:22
@Lujain16 That should not be the case. The Inspire HR, as does the Versa Lite, and I think all Fitbits now do, comes with small and large straps in the box. It's just one half of the strap that is different sizes. The other strap might have been in a separate compartment within the box if you didn't carefully open it all. That should be the same with the Versa Lite also. That said, the Versa Lite does have some advantages over the Inspire HR, so I hope you will be happy with it.
