10-12-2020
19:21
10:31
AlvaroFitbit
10-12-2020
19:21
10:31
AlvaroFitbit
My Inspire HR turn on and off with out moving any tip of how to reset it?
10:37
07:50
10-13-2020
10:37
07:50
@Nic25- Thanks for stopping by!
Let me help you with your unresponsive Inspire HR. Not sure if this is a display issue or a battery one so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device to discard a display issue and see how it behaves. You can follow these instructions to help your device charge.
Let me know how it goes.
