03-25-2019
10:18
11:22
YojanaFitbit
03-25-2019
10:18
11:22
YojanaFitbit
It would be nice to have the option to turn off the touchscreen / lock the screen and be able to open it only with the button.
Now, even with the screen wake disabled, the screen turns on if my shirt brushes up against the touch screen.
Moderator edit: Subject for clarity and labels and format.
07-16-2019 12:19
07-16-2019 12:19
Agree. It’s intended to wear while sleeping, but even in do not wake mode, the screen lights up every time it’s bumped. The screen should only go on with the button in this mode or there should be a turn off screen option. The screen should also not light up when the low battery notification comes up if the Fitbit is in do not wake mode. The light wakes me up every time and what normal person is going to stop sleeping to get up to charge their Fitbit?
08-14-2019 03:51
08-14-2019 03:51
How does the Inspire HR not have this feature when it was a default option for the Alta HR I just upgraded from.
08-14-2019 22:58
08-14-2019 22:58
Need this feature ASAP. Turn off touchscreen to avoid bright lights at night. Going to return it. Will pick it up again if this feature is added. It’s a sleep tracker for goodness sakes!
09-04-2019 13:21
09-04-2019 13:21
I found a suggestion elsewhere as my screen wouldn't come on until I pushed the button.
When the time is visible, hold the button in until you see the battery , scroll down, the next icon is screen wake. (tap on it to turn it off or on)
09-10-2019 19:02
09-10-2019 19:02
I too would love to turn off the touchscreen for boxing class. My gloves are constantly causing the touchscreen to go off. I even have wraps over it and it still goes off constantly. I have now ruined two Fitbits in 6 months and have bought and old refurbished one to wear for boxing class only.
09-11-2019 03:08
09-11-2019 03:08
Mine works perfectly.
Just keep the button tapped till you see the battery icon. Scroll down and you see a ballon icon, where you can turn off/on the screen.
You can also turn off the notifications if you scroll more.
Than keep the button tapped to return to clock
09-11-2019 04:04
09-11-2019 04:04
I understand how to turn off the screen wake feature. The problem is that the screen still comes on with either a screen tap or with a button push even when screen wake is off. It should not come on with a screen tap because this is too sensitive and it comes on frequently at night despite screen wake being off. Being woke up by the Fitbit light defeats its purpose as a sleep tracker.
10-02-2019 02:24
10-02-2019 02:24
And this is the reason I returned mine a few days after purchasing it. Every time the band touched the bed I was awaked. I liked the band but I can’t deal with that inconvenient light.
If the Team releases a firmware which fixes this (screen on only when the button is pushed) then it’d be a game changer feature for me and I’d purchase it again
01-29-2020 20:20
01-29-2020 20:20
OMG I searched for this forever found a video on youtube with a fix.
1. Hold the button for 3 seconds
2. Click the lightbulb so it is crossed out.
This will make it so the screen only turns on if you tap it twice or click the button. . . . Don't know why Fitbit makes this future different for every device.
07-09-2020 18:47
07-09-2020 18:47
For ME, even with the notifications turned off, it'll still turn on from a single brush or sometimes just a gentle breeze. And if I don't turn it off quickly, there's a 50% it'll start the timer just from subtle wrist motions. I don't want it to turn on unless I actually press the button. 😞
05-08-2021 17:26
05-08-2021 17:26
Fix this please, I'm almost ready to switch to another tracker because of the bright light interrupting sleep, Inspire 2 here.
05-08-2021 17:35
05-08-2021 17:35
You've tried the thing above, right? Holding the button for 3 seconds and then clicking the notification thing to disable it? I personally haven't had trouble in a long time so I guess I thought they must have fixed SOMETHING.
05-08-2021 19:59
05-08-2021 19:59
05-08-2021 20:29
05-08-2021 20:29
Sorry, had to ask. You know what people on the internet are like. Well, I hope someone has an answer for you.
