04-26-2025
15:25
05:09
04-26-2025
15:25
05:09
Hello,
My Inspire HR had 51% battery earlier today. Been about three says since charge. Now it is on 9%. It also will not charge to 100%, only 99%. I have turned off notifications. Help!
Thanks!
Best Answer04-27-2025 09:21
04-27-2025 09:21
Hi, @B_Marsh , as I am sure you are aware, all rechargeable batteries deteriorate over time, and the original Inspire HR is now quite an elderly device. Recharge batteries last a lot longer if they are well looked after, so it sounds like you have been treating yours really well if it is still lasting about 3 days and charges to 99%. Great job!
However, you will probably need to accept that pretty soon it will require a daily (or almost daily) recharge and that once it gets below about half it will drop very quickly. Sadly that is just the laws of physics… I don’t think there is help from this inevitability, but if you are willing to charge more frequently and it is still doing the job for you, then I expect you can get it to last a while longer yet.
If you have got on very well with the original Inspire HR, I think you will be really happy, once it comes time to upgrade, with the latest version in the Inspire series. I really like my Inspire 3 and it has some great improvements - for me the colour screen is the best change - so easy to see whatever the weather - and still the same neat outline on your wrist.
04-28-2025 03:49
04-28-2025 03:49
