Inspire HR won't charge
My battery no longer works and was wondering if anyone can relate to this? Did you end up having to buy a new Fitbit or did you find a way to change the battery.
3 REPLIES 3
My daughters is the same. Hoping its the charger.
Hey guys, thanks for your participation in the Forums.
@Tiaf, upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
@Ckelly2177, if you are having problems charging your unit, I recommend checking the article: Why isn't my Fitbit device's battery charging? and follow the instructions provided there.
Let me know the outcome.
Every time my Inspire won't charge, I clean the back of the device and the charger with an alcohol wipe (like you find in a first aid kit) and dry them thoroughly. Always seems to fix the problem.
