12-28-2021
08:58
10:04
12-28-2021
08:58
10:04
I've had an Inspire HR for several years but it had a problem so I removed it from the app and can't now reinstall it. The installation works normally until I reach the the point of connecting to the app. The Fitbit displays a four digit code and when I type this into the app the connection process starts but stops when the progress line reaches about a fifth of the way across the screen. After a long delay the app displays a "Something went wrong" message and the installation is aborted. I have tried resetting the Fitbit, checked that I have the latest version of iOS 12.5.5, and reloaded the app with the matching version.
Help please.
12-31-2021 10:07
12-31-2021 10:07
Hi there, @Opifex. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire HR before reaching out.
Please follow the steps below in the order listed:
Hope this helps.
12-31-2021 10:07
12-31-2021 10:07
Hope this helps.
01-02-2022 08:53
01-02-2022 08:53
Hi MarreFitbit
Thank you for your help installing my Inspire HR.
I tried your suggestions yesterday and found no difference except the time shown on the Inspire HR which had been wrong since I crossed a time zone three weeks ago was now correct. Today I did a factory reset, turned Bluetooth off on any nearby devices, and successfully installed the Fitbit on an Android phone. I then turned the Bluetooth off on the Android phone and tried installing on the iPad. After a few troubles with the Bluetooth connection it did eventually install successfully, so everything is now back to normal and the Inspire HR is synching with iPad.
Thank you again for your help.
Opifex.
01-03-2022 11:19 - edited 01-08-2024 06:57
@Opifex Awesome! I'm glad to hear that you managed to solve the issue.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
