03-04-2020
07:04
09:10
AlvaroFitbit
03-04-2020
07:04
09:10
AlvaroFitbit
won't display when flicking wrist, can't find setting
Best Answer03-05-2020 09:11
03-05-2020 09:11
@mas030 A warm welcome to our Community!
Let me help you with your Inspire HR not turning on when you turn your wrist. This feature is called Screen Wake (Quickview in some devices) and you can enable or disable it right from the tracker by long pressing the button.
Let me know how it goes.
Best Answer03-09-2020 13:24
03-09-2020 13:24
When I hold down the button (is that what you mean?), I get the battery percentage. It still doesn't display when i flick my wrist.
Best Answer03-11-2020 04:18
03-11-2020 04:18
The screen wake setting is a little lightbulb that should appear under your battery percentage, after you hold down the button.
You can tell if it's turned off because it will be dim and have a line through it.
Hope this helps.
