04-06-2019 15:13
04-06-2019 15:13
I have had my Inspire HR for a couple months now. My display won't turn on or sync to app and no green lights on back of device. This happened once before and I plugged it into the charger and held the button for 10 seconds and released it. That solved the issue. Today, not the same. I will get the smiley face and then nothing. So I gave up and tried again this afternoon. Still nothing. Please help.
08-19-2019 13:44
08-19-2019 13:44
My husband's Inspire was completely black on the screen. No time, no nothing. Only a vibration when we connected it to the charger. It had been that way for a week. I went into his Fitbit app and deleted his device. Then I re-added it. It began working after updating for about 5 mins.
09-04-2019 19:18
09-04-2019 19:18
Hi,
I was having the same problem with the Inspire HR. The screen does not display but the green light on back works and syncing work. Can anyone help me with this, please?
09-18-2019 06:30
09-18-2019 06:30
Same I woke up and it no longer worked. I have tried everything. I depend on this thing on my arm. It did clock my sleep though on app.
09-18-2019 16:47
09-18-2019 16:47
similar problem--after charging put it back on but a wrist rotation does not activate the screen. button will turn in on and everything else works (as for as I know). I tried restarting it but that did not make a difference.
09-19-2019 10:48
09-19-2019 10:48
09-21-2019 05:56
09-21-2019 05:56
09-23-2019 01:55
09-23-2019 01:55
Just woke up to this exact problem. Green lights face won't light!
09-23-2019 07:20
09-23-2019 07:20
09-23-2019 07:35
09-23-2019 07:35
10-21-2019 19:22
10-21-2019 19:22
I changed my clock face and it works now.
10-22-2019 07:20
10-22-2019 07:20
Hi, my fitbit seems to be doing the same as well.
I have tried the holding it down for 10 seconds to restart the fitbit but just seem to get the smiley face and then nothing.
Blank screen with no light on the back of the fitbit.
This a present i got for my mum so please help!
10-22-2019 16:27
10-22-2019 16:27
10-22-2019 18:07
10-22-2019 18:07
I have the same problem yesterday. I change the clock face and it works! Than change the origin I used work, too! Thanks for the help!
11-11-2019 06:03
11-11-2019 06:03
My inspire will not display anything. It vibrates as if responding but nothing displays. It syncs with the app and shows it’s fully charged. I tried restart but still nothing. I purchased one from Walmart at the beginning of the year. It did the same thing within a couple months so exchanged it. This Is that replacement but has had the same problem off and on usually responding after being charged. I’ve tried the restart several times in the last 24 hours.
04-06-2020 08:41
04-06-2020 08:41
Ive tried cleaning the contacts, resetting but nothing has happened. No green lights. Everything black and my app says no device connected now.
whats the next step? Replacement?
04-22-2020 02:00
04-22-2020 02:00
I am also facing the same problem. When tracker is pressed for long time only smile comes nothing else. It buzzs also. I don't know what to do. Sent a mail to fitbit but they have asked to do same procedure likhbt cleaning of charging points which I am fed up of doing again and again.
06-24-2020 16:10
06-24-2020 16:10
I am literally having the exact same problem as JenR1974. I am almost in tears! My Inspire HR isn't even a year old. How do we fix this? Please help!
06-24-2020 16:47
06-24-2020 16:47
06-25-2020 18:35
06-25-2020 18:35
08-15-2020 08:46
08-15-2020 08:46
The same thing is happening to me! My device just has a flat line.... Very disappointing! I'm about to call support for help. I purchased the Inspire hr to replace my old Charge the oddly stopped working about a month ago...
