12-10-2019
11:18
10:01
AlejandraFitbit
12-10-2019
11:18
10:01
AlejandraFitbit
I can't do nothing besides check a time. The touch doesn't work good I think it is awash. But I don't know when it washed. It is waterproof and I took a bath in this watch.
Best Answer12-10-2019 14:16
12-10-2019 14:16
Hi @22Mischelle22 Try restarting the I spire several times. If the touch still doesnt work then please come back here.
Helen | Western Australia
10:02
06:01
12-12-2019
10:02
06:01
Welcome to the Community, @22Mischelle22 and @NellyG, thanks for the input.
I was able to see here that our friend @NellyG provided some instructions in order to fix this swipe issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best Answer12-12-2019 15:14
12-12-2019 15:14
There is a problem with your link! It specifies the question and list reasons why you would need to, but does not say how to.
Best Answer12-12-2019 17:05
12-12-2019 17:05
I found it
Best Answer12-12-2019 17:30
12-12-2019 17:30
Mine is doing this also even after trying to reset a few times. The customer service chat also won't work right now. Is there any additional advice?
09:39
06:01
12-13-2019
09:39
06:01
Thanks for your participation in the Community and for the efforts in trying to fix this swiping issue.
@Stupidav, I would like to know if the restart process worked? Were you able to perform this?.
@Wolfsene, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Let me know if you need anything else.
