01-20-2021
12:01
03:16
JuanJoFitbit
01-20-2021
12:01
03:16
JuanJoFitbit
I've been having problems with my fitbit for about 2 weeks.
Not it doesn't work at all.
The display will not come up, I can
charge it for hours and the green light won't come on.
It's dead.
I think the battery has gone bad.
I've called support and no help.
Any ideas?
Can the fitbit be opened and the battery replaced?
It's out of warranty by a month.
Best Answer01-21-2021 03:15
01-21-2021 03:15
Hi @Les123, it's great to see you in our Fitbit Community. Regarding the screen and charging issue that your Inspire HR experienced, I appreciate the time spent trying to get them resolved before contacting our forums.
I'm sorry to hear that your Inspire HR is no longer under the warranty period. I totally understand how you feel about this and we appreciate your feedback and comments since this helps us to keep improving.
I'll be around if any question arises.
Best Answer01-23-2021 10:08
01-23-2021 10:08
My Fitbit is a month out of warranty.
You think you could at least send me a
discount code to buy a new one
Best Answer01-23-2021 16:30
01-23-2021 16:30
My husband’s Fitbit is doing the same thing! I’m so frustrated because the Fitbit shouldn’t b having issues after 13 months!
Best Answer01-26-2021 09:54
01-26-2021 09:54
I'm frustrated. It is completely dead.
I've really enjoyed using the fitbit. It has helped me stay motivated.
It has helped me lose weight and get into better sharp.
Now it's 13 months old and it stops working.
It should last long then that.
Is this a common problem with these Fitbits?
After 13 months it stops working.
So you have to buy a new one.
