04-27-2019
23:11
08:59
AlejandraFitbit
04-27-2019
23:11
08:59
AlejandraFitbit
I put my Fitbit Inspire HR on the charger as I had previously done, but the display has stayed black, and it is randomly vibrating. Sometimes, a happy face will appear, then fades away and the screen stays black.
Best Answer04-28-2019 09:00
04-28-2019 09:00
Hey @LDHowlett, welcome to the Forums.
If your tracker isn't turning on, I recommend restarting it by doing the following:
Let me know the outcome. 😊
04-28-2019 09:00
04-28-2019 09:00
04-28-2019 09:40
04-28-2019 09:40
My Hr is doing the same thing.. vibrates and screen stays black!
did all the steps above and did not fix! This is my second one in a month...
04-28-2019 14:01
04-28-2019 14:01
i have the same problem, the smile comes on for about 8 seconds and the screen goes black and nothing comes on. Very Disappointed!!!
04-28-2019 19:05
04-28-2019 19:05
I am having the same issue. The inspire would not turn on after trying to restart it multiple time been a week since i've been trying these steps almost daily hoping that somehow the firmware will be updated and this issue might go away. But what I understand from the research online is that this issue is pretty common with Inspire HR and that others have already got their fitbit replaced as it cannot be fixed. Does anyone know if replacement or return is the only way out?
04-29-2019 07:00
04-29-2019 07:00
Hey guys, thanks for your participation in the Community.
I am sorry to hear about your disappointment and appreciate all the efforts in trying to fix this display issue.
Have you tried to change your clock faces? If you haven't, I recommend trying this by following the instructions provided in the help article: How do I change the clock face on my Fitbit device?.
I will see you around. 😉
04-29-2019 16:54
04-29-2019 16:54
I am having the same issue. I can't change the clock face, because my Fitbit app can't seem to find my Fitbit.
After the smiley face appears and then disappears, the Fitbit does a quick vibration pulse every 30 seconds or so, but the screen is staying dark.
04-30-2019 10:38
04-30-2019 10:38
Hello. I’m having the same issue. My battery isn’t low but the screen will stop working. I’ll feel random brief buzzes from the device but nothing will show on the screen. If plugged into the charger and attempting to reset by holding the button, nothing happens. I go days without it working and then it’ll randomly come back to life. Is there any fix to this?
05-01-2019 19:21
05-01-2019 19:21
We are having this EXACT issue with my son’s inspire HR. He has had it less than a month ☹️
05-02-2019 14:07
05-02-2019 14:07
I'm having this exact issues as well.
Screen is dark, Fitbit App can't find Inspire HR, If I try to reset it I get smiley face then dark screen and an intermittent quick pulse vibration.
05-02-2019 23:37
05-02-2019 23:37
Same problem here, black screen, can get the smiley, but factory reset doesn't actually do anything for me. Fully charged, no connection through bluetooth or usb with neither Windows or Android.
05-03-2019 10:23
05-03-2019 10:23
I have done those steps several times with the same outcome. Do I just need to contact fitbit to get a new one? I really haven't been able to fully set it up, so I won't lose any data.
05-03-2019 23:31
05-03-2019 23:31
I am having the same issue just bought this to replace a dead Alta HR and I am NOT HAPPY
05-04-2019 10:47
05-04-2019 10:47
I'm having this same issue. I've tried restarting the Inspire HR, but nothing happens. When on the app it shows that it hasn't synced since April 22nd. My app can't even find the device let alone sync. I've kept it dry and charged. I've not hit it against anything to cause damage. The app says there is an update available but if it can't even find my Inspire HR, how am I supposed to update it?
05-04-2019 14:33
05-04-2019 14:33
I am having the same problem. I just got mine.
05-07-2019 14:18
05-07-2019 14:18
Judging from the responses on this exact same scenario, I would venture to say this officially is an issue with the Fitbit Inspire or Inspire HR. I have tried both solutions suggested by Fitbit Techs, and neither resolved the issue, which, by the way, is that our Fitbit Inspire's have shut down and won't turn back on. Since no one is reporting a solution for this issue, why hasn't Fitbit been contacting us and offering to replace our defective units? These aren't cheap. Might I be so bold as to suggest that someone from Fitbit Customer Service tap into this conversation and contact each and every person who participated (or participates at a future date), and resolve this issue. If no one from Fitbit contacts me in the next 5 days, I will have to post this entire message on Facebook and see how that works, then Twitter, Instagram, etc. I'm sure Fitbit will have no choice but to take notice and resolve this issue.
05-07-2019 15:47
05-07-2019 15:47
05-08-2019 11:29
05-08-2019 11:29
Maybe a phone call is what I need to try. I've been trying to speak with them over e-mail and it's been one of the more frustrating customer support experiences of my life. They have offered a replacement after I mail mine in, but I'm trying to determine what steps they have taken to ensure I won't be going through all of this again in another 2 weeks.
05-08-2019 12:06
05-08-2019 12:06
05-08-2019 12:10
05-08-2019 12:10
