04-27-2019
23:11
08:59
AlejandraFitbit
04-27-2019
23:11
08:59
AlejandraFitbit
I put my Fitbit Inspire HR on the charger as I had previously done, but the display has stayed black, and it is randomly vibrating. Sometimes, a happy face will appear, then fades away and the screen stays black.
06:19
08:37
DavideFitbit
04-27-2021
06:19
08:37
DavideFitbit
Well David, so I see a new Fitbit replacement has absolutely no warranty then. I'd love to chat to the Head Person in charge or even send back this Fitbit that was suppose to be new in late Dec. .
I've had so much trouble with the Inspire HR ever since they came out. As you will notice so have about 95 % of the people in this forum are complaining about the same issue with the Inspire HR. Maybe this company needs to look at what all the problems are with them lasting about 3 months...it's a big rip off as far as I am concerned. I had another Fitbit for almost 4 years no problems..
Moderator edit: word choice
Best Answer04-27-2021 08:41
04-27-2021 08:41
Thank you for sharing your feedback about your experience with the Inspire HR and the warranty policy, @ShelleyLF.
In order to talk to somebody, I recommend that you give us a call, since this option is not available through the Community Forums. Click here to get connected.
Thank you again for all your feedback.
04-28-2021
10:26
10:43
AndreaFitbit
04-28-2021
10:26
10:43
AndreaFitbit
I'd like an address for someone important. Not the call center. I'd love to return all the crappy fitbits you've sent
sad to think a product last no longer than 3 months.....maybe mention that to the CEO!
Moderator edit: format.
Best Answer04-30-2021 05:54
04-30-2021 05:54
Thank you for your reply, @ShelleyLF.
There is no direct contact for what you mentioned, but if you get in touch with the Customer Support team, you can ask them to forward your information to someone else to check if they can provide you with more information about this.
Have a great day.
06-11-2021 16:51
06-11-2021 16:51
good luck with that D Towle jr, It has been 2 years plus, any response? I have same issue, I am going to let the battery run down completely, then recharge and try again.
good luck; prisonface, midwest
Best Answer06-12-2021 14:52
06-12-2021 14:52
Welcome to the Community forums, @prisonface.
Thank you for sharing that you've been experiencing the same inconvenience with your Inspire HR device.
Before considering other options, if this is related to the display, let me know if you've tried the restart procedure, and the steps listed in this article in case that this problem is more related to the battery.
Hope this helps.
Best Answer06-14-2021 08:23
06-14-2021 08:23
Your mileage may vary. I just bought a new Inspire HR that won't turn on, and the customer service rep told me I needed to perform a system update on a mobile phone. I don't own a mobile phone. I asked how to go about getting my money back and she rudely told me to return it where I bought it, and then hung up on me without another word. Why on earth would Fitbit not make it clear that a mobile phone is REQUIRED to use these devices? You shouldn't just assume that everyone has one. This is one of the worst companies I've ever had the misfortune of dealing with, and the customer service was appalling.
06-15-2021 11:56
06-15-2021 11:56
Welcome to the Fitbit Community forums, @SPRobson.
I'm sorry to see that you've experienced this inconvenience with your new Inspire HR.
Although it's true that most users use a mobile device to sync their data, it is possible to do it through a computer as well. Whether it's with the Fitbit app installed on the computer or with the Fitbit Connect program, but not all devices appear on the list when you try to set up with the PC, so it is recommended to set up using a smartphone, if possible.
Regarding the firmware update, you can also try to follow the instructions here to complete it using a computer, but I understand if you already returned the device due to these inconveniences. Thank you for taking the time to share your feedback about the product and Customer Service as well. If you wish to contact them through a different channel, you can also chat or send us an e-mail. Click here to get connected.
Have a great day.
Best Answer06-17-2021 06:49
06-17-2021 06:49
My Inspire HR stopped working too. I noticed it was running low on battery yesterday and so it has been charging since then, but it will not turn on anymore. It showed a smiley face a couple of times after pressing the button for 10 seconds, and then this disappeared. My phone app does not recognise a connection to it either.
Best Answer06-17-2021 10:17
06-17-2021 10:17
Welcome to the Community forums, @Gemscluey.
Thank you for sharing that you're having the same inconvenience with the Inspire HR.
Could you please confirm if you already tried all the steps mentioned here previously? And let me know if you continue to experience the same difficulty to turn the device back on.
Hope this helps, I'll be around.
Best Answer06-18-2021 02:36
06-18-2021 02:36
hi Davide,
I've tried all of those steps but the device just won't turn on at all.
I don't know if it just died so hasn't been charging at all since yesterday, and every time I plug it in to try charging it, the device becomes very hot (not the USB charing cable though).
I appreciate any help with this. Thanks
12:55
09:12
DavideFitbit
06-19-2021
12:55
09:12
DavideFitbit
Hey I am having same exact problem....have done everything suggested and still won’t work....so tell us DavideFitbit how can we fix it?
Best Answer06-22-2021 09:12
06-22-2021 09:12
@Gemscluey @mjco Thank you for your reply and confirming that you already tried all the suggested troubleshooting steps.
In this case, since you already tried the all the suggestions shared in the Community forums, the best way to get more immediate help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a great day.
16:11
11:52
DavideFitbit
06-22-2021
16:11
11:52
DavideFitbit
It get the smile, but no vibration. Time and stats show up while on the charger but I have a black screen on my wrist. It refuses to sync.
Exactly! So frustrated!
Best Answer06-23-2021 05:36
06-23-2021 05:36
I think I solved this...for me at least.
Here's what I believe is happening: you're not holding the button long enough.
If the battery is reeeeally dead, it won't charge properly.
If you put it on the charger, press and hold side button for ONLY A COUPLE SECONDS, the smile face will appear, device reboots, problem NOT solved.
If you hold the button for like TEN SECONDS, the device will reboot twice.
Keep doing this every couple of minutes for maybe 3 cycles, allowing the battery to charge a little each time.
Then take it off the charger once you've attained sufficient battery level. Hope this works, sorry if it doesn't.
Best Answer06-23-2021 11:50
06-23-2021 11:50
@Cayematthews Thank you for sharing that you're experiencing the same inconvenience with your Inspire HR and that you already tried the troubleshooting steps mentioned earlier. If you already tied the restart procedure and you were able to see the smiley face after holding the button for a at least 5 seconds, I do recommend that you contact the Customer Support team here so they can provide you with further instructions.
@g_bren Thank you for taking the time to share the solution that you found for this problem. I'm sure this will be useful for other users as well. 😎
Have a great day.
Best Answer07-30-2021 03:31
07-30-2021 03:31
I have the same issue! Tried chat online and got ignored for 15 minutes. Waisted time!!! My Fitbit is absolutely black! Never turn on!!! Waisted time and money I’m really disappointed
Best Answer07-31-2021 05:34
07-31-2021 05:34
Best Answer08-03-2021 09:38
08-03-2021 09:38
Thats my next move since the "new" Inspire keeps not getting my notifications for it to work properly I have to manually sync it every couple of hours. Its not my phone since I just pull down on the Fitbit app and it works for a couple of hours. Fitbit has become expensive for it to have so many problems.
Best Answer08-05-2021 22:05
08-05-2021 22:05
Didn’t work for me 😕
