04-27-2019
23:11
08:59
AlejandraFitbit
04-27-2019
23:11
08:59
AlejandraFitbit
I put my Fitbit Inspire HR on the charger as I had previously done, but the display has stayed black, and it is randomly vibrating. Sometimes, a happy face will appear, then fades away and the screen stays black.
09-09-2019 13:09
09-09-2019 13:09
Hi,
My Inspire HR turned off randomly for the first time today (I've had it for 1 month). Battery was at 57%.
I've restarted it, and all is good now.
I read somewhere that the display will turn off if the fitbit is covered up; is this why my fitbit turned off? I had it under my jacket for a while. Please let me know!
I love my Fitbit and don't want to have to replace it!
09-10-2019 16:52
09-10-2019 16:52
I have the smile and it vibrates. However, when I go on my phone to set up this new fitbit (different model than my old one), it says that someone already has my email. (It's the one I used when I had my Alta.)
What do I do?
09-10-2019 16:54 - last edited on 11-08-2019 13:05 by LiliyaFitbit
Try deleting the Fitbit app and then reading it.
09-10-2019 16:59
09-10-2019 16:59
09-10-2019 17:40
09-10-2019 17:40
09-11-2019 17:19
09-11-2019 17:19
Worked like a charm!! Thanks
09-18-2019 18:31
09-18-2019 18:31
With hand movement, it’s not turning on...what is that we need to do to this problem?...my earlier charge 2 stopped working in less than 5 years (life of your products) and so bought this last month...why are you making these products for people to figure out fixes wasting a lot of time....
09-18-2019 20:36
09-18-2019 20:36
09-20-2019 02:54 - edited 09-20-2019 02:56
Hope your fitbit is working well.....If it does, don't assume it will be forever....fitbit has to learn from iPhone on making products that will function.....My fitbit doesnt turn on with hand movement, although it worked day 1. Somewhere I ready that we try changing clock faces......no wonder fitbit stock is $3.67...this is where all will reflect...good luck!
09-29-2019 13:10
09-29-2019 13:10
Mine is doing the very same thing
09-30-2019 05:31
09-30-2019 05:31
Changing the clock faces on the app worked
10-02-2019 10:52
10-02-2019 12:13
10-02-2019 12:13
Me again.
My fitbit ran out of battery. Now I'm charging it and it won't turn on at all. Before I was just having the synch issue (which resolved with teh clock change workaround).
But now it's like it's bricked. What do I do? Its just an expensive, useless bracelet now.
10-03-2019 05:43
10-03-2019 05:43
10-12-2019 02:11
10-12-2019 02:11
I am on my second one in 6mths, first one was replaced under guarantee and its now doing the exact same thing as the first one, I have managed to get it going this time, but the first one did restart and then stopped restarting even after following the below steps hence getting it replaced, hope this one doesn't go the same way.
Total fed up of it, my old fit bit which I had 3years never had a single issue, I just wanted a waterproof one and that was the only reason I changed, wished I hadn't bothered, if I still had my old one I would be back to using it.
very disappointed and wont be buying an other.
10-12-2019 02:50
10-12-2019 02:50
10-13-2019 08:01
10-13-2019 08:01
Thank you so much it worked.
10-20-2019 20:12
10-20-2019 20:12
I'm having the same issue.
Right out of the box.
Within the hour of it fully charged and setup.
I walked 1 mile and when I checked the screen, it was off. Pressing the button did nothing.
The app indicated it was fully charged. When I plugged the Inspire to my computer, it turned on and it indicated a full charge. But the moment I unplug it, it turns off.
I tried the reset, unpairing and pairing again, changed the clock face and it still has the same problem.
Really wanted to track my sleep to get better at getting more sleep per night but this problem already has kept me up an hour past my bedtime lmao
10-20-2019 21:54
10-20-2019 21:54
The smile face came and went. I let the button go during one smile period and the screen came back to life.
Thanks.
11-03-2019 08:01
11-03-2019 08:01
I'm having the same issue as originally reported. I plugged it into charge and it showed the smiley face once. Since then, it's been totally black. My phone can't detect the device anymore (it last synced yesterday evening), so I can't change the clock face. I've tried restarting repeatedly by holding the button down for 8 seconds and releasing. It's also not showing the battery logo when I plug it in and never vibrates from any action. Basically, it seems like it totally bricked after initially showing the smiley face. It actually shouldn't even be out of batteries - was at 60% yesterday evening.
