04-27-2019
23:11
08:59
AlejandraFitbit
04-27-2019
23:11
08:59
AlejandraFitbit
I put my Fitbit Inspire HR on the charger as I had previously done, but the display has stayed black, and it is randomly vibrating. Sometimes, a happy face will appear, then fades away and the screen stays black.
Best Answer05-26-2019 14:50
05-26-2019 14:50
Fitbit sent me a replacement.
Best Answer05-26-2019 20:39
05-26-2019 20:39
Best Answer05-27-2019 18:55
05-27-2019 18:55
I have been so crazy busy since I posted my original message, but have been following everyone's comments. It's crazy how many people are having the same issue! I am going to call customer service this week! Thank you EVERYBODY for the great info!!!
Best Answer05-31-2019 13:36
05-31-2019 13:36
This does not work, as I bought it overseas from my current location how do I get it replaced?
Best Answer05-31-2019 14:33
05-31-2019 14:33
Best Answer05-31-2019 17:55
05-31-2019 17:55
So... I just called customer support. Got the usual troubleshooting: plug it in, try to restart, try to connect with iPhone, try to update software - again, no progress. They are opening an escalation case, from which an e-mail will be sent to me in the next 24-48 hours, and then I will follow those instructions, when it shows up.
Did all of you guys have that experience? Or did they handle the replacement immediately on the phone?
Best Answer05-31-2019 18:27
05-31-2019 18:27
Best Answer05-31-2019 18:34
05-31-2019 18:34
I appreciate your quick response. 🙂
Best Answer06-02-2019 05:59
06-02-2019 05:59
Me too. Just nothing working. One-month-old Fitbit won't work. Display black.
Best Answer06-03-2019 11:45
06-03-2019 11:45
I can not power on my inspire HR. The smile face comes on for a few seconds and then shuts off. The watch vibrates every few seconds.
Best Answer06-03-2019 11:46
06-03-2019 11:46
I can not power on my inspire HR. The smile face comes on for a few seconds and then shuts off. The watch randomly vibrates. Can not power on!
Best Answer06-03-2019 13:02
06-03-2019 13:02
Best Answer06-04-2019 00:42
06-04-2019 00:42
Reported it via the chat function where they established it had undergone a critical failure. They will be replacing it shortly. Sounds like you should do the same!
Best Answer06-17-2019 12:11
06-17-2019 12:11
This happened to me with my Inspire HR as well. After trying everything from the website and this thread, I called customer service. They were helpful and are sending me a replacement. The replacement has 30 day warranty of it's own and then the remainder of the original warranty applies to the replacement. That's what I was told when I expressed concern with so many people seeming to have the same issue.
Best Answer06-18-2019 10:19
06-18-2019 10:19
Similar issue ,it just won’t turn on ,tried diff plug in ,reinstalled app ,did all as per helpline guide ,but it refuses to charge ? Is it a faulty product ,?sad real sad
Best Answer06-18-2019 10:22
06-18-2019 10:22
It’s an identical issue with me ,is product a misfired one ,has it not gone thru rigour of r n d 😐sad
Best Answer06-18-2019 10:23
06-18-2019 10:23
same issue ,I thk product is faulty one
Best Answer06-19-2019 04:33
06-19-2019 04:33
Best Answer06-19-2019 21:21
06-19-2019 21:21
Best Answer06-20-2019 06:33
06-20-2019 06:33
The same issue just happened to me also, and I cannot be able to contact the customer service also, the helpline is always busy.
I don't know when they're going to clear the line and pick up the call.
Hoping someone from fitbit india, addresses the issue.
