04-27-2019
23:11
08:59
AlejandraFitbit
04-27-2019
23:11
08:59
AlejandraFitbit
I put my Fitbit Inspire HR on the charger as I had previously done, but the display has stayed black, and it is randomly vibrating. Sometimes, a happy face will appear, then fades away and the screen stays black.
Best Answer02-05-2020 07:44
02-05-2020 07:44
So I hopefully have good news for you because I fixed mine.
I believe it was caused by something (maybe a software update?) booting me out of my app and messing up the Bluetooth.
1. Go to app
2. Log in
3. Enable Bluetooth connectivity through Fitbit app (should be at the top of the screen like a warning)
4. Should be connected now and turning on.
If you're not logged out, then perhaps try logging out and logging back in.
Hopefully this was your fix too! So strange, but I guess this must be it's anti-theft technology in action?
02-06-2020 22:34
02-06-2020 22:34
Best Answer02-07-2020 07:43
02-07-2020 07:43
Can you restart it without the charger
Best Answer02-09-2020 10:14
02-09-2020 10:14
Fitbit inspire turned off tried holding button 5 seconds nothing happens
Best Answer02-10-2020 10:12
02-10-2020 10:12
How did you go about getting the replacement?
02-10-2020 21:43
02-10-2020 21:43
Best Answer02-17-2020 20:10
02-17-2020 20:10
This worked instantly! Thanks so much!
Best Answer02-18-2020 11:24
02-18-2020 11:24
Best Answer02-21-2020 06:31
02-21-2020 06:31
Best Answer02-28-2020 14:56
02-28-2020 14:56
My screen wentwent black 2 days ago. It was still synching with the app and the battery was not low. But today it just randomly started working again. And I didn't do a restart because I just started researching the issue today.
Weird....
Best Answer02-29-2020 09:21
02-29-2020 09:21
Best Answer03-06-2020 09:25
03-06-2020 09:25
My son's Fitbit won't start at all. Connect it to the charger and it doesn't even vibrate. Tried holding the button down for five seconds while connected and nothing - just a black screen. Is is bricked?
Not sure we still have the receipt, is he scuppered?
Best Answer03-07-2020 16:22
03-07-2020 16:22
@EhBoy - use these instructions to restart your Fitbit - https://help.fitbit.com/articles/en_US/Help_article/1186/
If that doesn't work for some reason, reach out to Fitbit Support!
@Fitbit - FYI, my replacement Fitbit Inspire HR also had the screen issue (where the screen doesn't activate, even on a full charge). I didn't find out until I was running errands and tried to check the time. Comically, hours later, I felt the triple vibrate which meant I had beat my record or was doing great or something?
Going to sell my Fitbit and spring for another fitness tracker. It's crazy I can't even dependably use this to tell time. 😭
Best Answer03-08-2020 01:25
03-08-2020 01:25
Thanks @SunsetRunner
I did try those instructions to no avail.
Been in contact with Fitbit now and they assume a battery failure. A replacement is on its way.
Best Answer05-12-2020 12:23
05-12-2020 12:23
My Fitbit Inspire HR will not turn back on. I have tried the restart several times and it will not restart. It will not turn on and it is only 6 months old.
Best Answer05-22-2020 11:20
05-22-2020 11:20
My Inspire HR won't turn on at all. I have to say that is has been the most disappointing tracker I've ever had. Going to look for another brand at this point.
Best Answer05-22-2020 17:10
05-22-2020 17:10
Thank you for this advice. My Inspire HR screen would not turn on, The watch was on but the screen was not working and I could not get a sync to work.
I tried your advice and bingo, screen is working again.
Thanks,
Jim
Best Answer05-23-2020 06:56
05-23-2020 06:56
05-23-2020 07:37
05-23-2020 07:37
Best Answer05-23-2020 08:19
05-23-2020 08:19
This continues to happen on a $100 item and now nothing is fixing this. Have tried everything suggested. Want money back or real fix ASAP. No excuse for this. I've sworn not to buy another Fitbit due to these problems but gave in just four months ago and constantly have same problem. Defect.
