Inspire HR wont charge at all
Wont charge at all ,only 2 months old and connected  properly.
1 REPLY 1
@Kimberlywalsh Thanks for joining us! Sorry for the delay in my reply.
Let me help you with your Inspire HR not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
Alvaro | Community Moderator
