03-22-2019 08:26
03-22-2019 08:26
I just got an Inspire HR and I can not get it to pair with my Galaxy S9 bluetooth. I have tried several things and it still won't pair. Any suggestions? thanks
Best Answer04-10-2020 08:27
04-10-2020 08:27
Best Answer04-10-2020 08:29
04-10-2020 08:29
Best Answer04-10-2020 08:30
04-10-2020 08:30
Doesn't work for S9. But I just walked into the room where my fitbit is laying on the table and it found the fitbit. It's junk.
Best Answer04-10-2020 09:41
04-10-2020 09:41
04-11-2020 00:08
04-11-2020 00:08
Yeah sound good. I hope it works out for you. The hacks all seem to work randomly and some watches seem to work for and some it seems not, its all a bit of a ball ache when it doesn't, and shouldn't really be taking people hours and hours to try figure out. Any way I tried and tried for 3 months... Gave up, got an alternative! Goodluck with yours 🙂
Best Answer04-11-2020 00:09
04-11-2020 00:09
Best Answer04-23-2020 07:23
04-23-2020 07:23
how did you do this ? mine will not connect
Best Answer04-23-2020 08:59
04-23-2020 08:59
Unlink, delete the app. re add the app and try relinking.
It took me a few tries but I got it. so frustrating.... if this ever dies I will not replace it with another product
Best Answer04-23-2020 09:06
04-23-2020 09:06
Best Answer04-23-2020 09:13
04-23-2020 09:13
Where is this screen? How do I get there???
Best Answer04-23-2020 09:17
04-23-2020 09:17
I tried this and I still can not get my Inspire HR to sync. It doesn't sync with my phone or with my computer. As far as I'm concerned the only good thing the watch does is let me know how far I walked, how fast I walked and how long I slept. Oh yeah and it tells time!!!
Best Answer05-16-2020 15:07
05-16-2020 15:07
That worked. Thanks!
Best Answer06-15-2020 10:01
06-15-2020 10:01
I . cant get my inspire to pair with my iphone. It does not even show up as a paring option on my app. I am using an iphone
Best Answer06-15-2020 12:42
06-15-2020 12:42
06-23-2020 06:14
06-23-2020 06:14
Mine wouldn't pair on my galaxy s9 either. I could see that Bluetooth found the Fitbit because it was there showing as a connectable device but when I tapped it to pair it wouldn't pair until I did this:
I hope this helps you.
Lynda
06-23-2020 06:22
06-23-2020 06:22
@vla12 wrote:I just got an Inspire HR and I can not get it to pair with my Galaxy S9 bluetooth. I have tried several things and it still won't pair. Any suggestions? thanks
Go into settings on your phone
tap connections
tap Bluetooth
Tap th three little buttons in top right corner
tap advanced
tap Bluetooth Control History
Find the Fitbit app logo and tap it
then I just followed the prompts after this......
fyi it took a long time to connect- it appeared to be updating the software showing 1 of 3, 2 of 3 and finally 3/3 if you know what I mean
Lynda
06-23-2020 06:35
06-23-2020 06:35
06-23-2020 06:59
06-23-2020 06:59
Best Answer06-23-2020 14:16
06-23-2020 14:16
06-27-2020 09:32
06-27-2020 09:32
watch just says fitbit.com/setup Phone says bluetooth on. fitbit app is showing today with categories of today underneath. Never suggests anything about pairing. want to sell me a subscription for "Premium"
I bet it'd work with that, but I'll throw it away first.
