06-03-2020
21:39
07:02
AlvaroFitbit
06-03-2020
21:39
07:02
AlvaroFitbit
the watch won't stay on ive rested it over and over again it only stay on for a while then is off what can I do its only 3 months old
07:03
06:53
06-08-2020
07:03
06:53
@Serinarose It's great to see that you've visited the Fitbit Community!
Let me help you with your Inspire HR not keeping a charge and thank you for troubleshooting this issue. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
