04-16-2019
07:48
06:40
JuanJoFitbit
04-16-2019
07:48
06:40
JuanJoFitbit
I'm finding the Inspire HR heart rate monitor is inaccurate especially at higher BPM. I was at the gym exercising on a ARC Trainer. The Fitbit had my heart rate at 101 and the ARC, which has a built in HR monitor in the handles, showed 124. I moved the Fitbit low and high, top and bottom of the wrist plus loosened and tightened the band. It still was well under in it's accuracy. This has also happened while climbing steps outside the gym and I took my own pulse. The Inspire HR is consistently inaccurate.
Anyone else?
Moderator edits: title and body for format
Best Answer04-16-2019 08:08
04-16-2019 08:08
I have also same "feature". 126 is max heart beat i have seen..
Best Answer04-16-2019 11:45
04-16-2019 11:45
Just found that if I look at the Resting Heart Rate menu for Sunday it has my highest heart rate at 129, BUT if I check the Exercise icon for the SAME TIME it's 144. What is that all about????
04-18-2019 09:35
04-18-2019 09:35
My fitbit consistently registers about 20 bpm lower than it should. I put on my husband's Charge 3 on my right hand, took readings of both during rest and during activity.
04-19-2019 07:11
04-19-2019 07:11
Was the Charge 3 more accurate?
Did take your own pulse off the wrist or jugular to verify?
Thanks for your feed back.
Best Answer04-19-2019 13:34
04-19-2019 13:34
Hi, I've also found the Inspire HR inaccurate at high BPM - mine seems to overstate the heart rate - it recorded me as 209 beats per minute sustained and on a bike ride it had me doing 192 bpm both way above what I should be capable off.
Recently I've worn my wahoo heart rate tracker (chest strap) that's always in line with the ones in the gym so tend to trust that and it's consistently around 10% less than what the Fitbit is saying.
If a moderator is reading this I've tried wearing it on different wrists, experimented with moving it up and down my wrist and having the strap loose and tight - it still seems to to overstate my heart rate - any suggestions?
04-19-2019 13:40
04-19-2019 13:40
Best Answer04-29-2019 04:41
04-29-2019 04:41
Same problem
old fitbit max heart rate 164 now 130 with same run
bogus
04-29-2019 07:48
04-29-2019 07:48
I'm finding that if I start an "exercise" on my watch before a power walk, steps or weights it give a more accurate HR
05-04-2019 13:04
05-04-2019 13:04
Best Answer06-25-2019 22:40
06-25-2019 22:40
During my MMA training, when I feel I am at maximum exertion, my Inspire shows HR in the “cardio” range. I highly doubt it’s at 150 bpm max, since I can barely breath and give it all my energy. Seems the HR readings are off. Any word from FitBit on this?
Best Answer06-26-2019 04:59
06-26-2019 04:59
I have the exact opposite
My new inspire has me 20 beats low during maximum exercise compared to my old Fitbit
have done everything, exercise mode, reinstall,
06-26-2019 06:28
06-26-2019 06:28
07-01-2019 18:07
07-01-2019 18:07
My Inspire HR seems to very inconsistent with the HR is displays. I think it does a good job at resting HR. But there are times when it shows 90-100+ when I know it’s nowhere near that high (a manual check shows it to be upper 60s/low 70s). Or I know my HR is raised and it shows much lower unless/until I press the tracker into my wrist and hold it there a while before it adjusts. I just had a cardiac stress test (treadmill) and the EKG showed my peak HR reached 173, but my tracker topped out at only 103! I’m ready to return it...
09-21-2019 03:29
09-21-2019 03:29
Inspire HR seems to be more influenced by your movements than your heart rate. When it should have been approaching 180 it showed less than 130. On an exercise bike with HR consistently in 140's it showed 70. The graph of the heart rate often shows it increasing, then suddenly dropping low when working harder.
Like others I have tightened and loosened the strap, moved it higher and lower, changed wrists and even tried it on the inside of my wrist, but it would still never show my actual hear rate during exercises.
It doesn't do what I bought it to do.
It seems to be more for encouraging sedentary people to move than for those of us who regularly push themselves.
09-21-2019 03:57
09-21-2019 03:57
10-02-2019 10:04
10-02-2019 10:04
I too have this problem. I'm kind of glad to know I'm not the only one! I feel like I'm exerting myself and the Inspire HR isn't recording it properly, it's very frustrating. Please do something about this!
05-13-2020 12:18
05-13-2020 12:18
I have notice the same thing. When I check my heart rate during exercise it is always higher than what I seen on the daily heart rate, sometimes as much as 30 BPM more! Which is correct? I need to know.
07-22-2020 06:38
07-22-2020 06:38
My Fitbit Inspire is ok for Resting pulse (50–53), but crazy at Max where it credits me at 160bpm or more sometimes. At my age of 76 it should be in ballpark of 220 – 76 = 144.
When I did hills with a Polar chest strap around age 70 it was at max of around 153 really pushing it.
Any solution or explanation for this type of inaccuracy?
02-08-2021 10:52
02-08-2021 10:52
I found that it can't track heart at rest. During intense crosstraining it's all the place. One moment it's reading 132 a minute later it is reading 72. Going with Samsung and taking this out to the shooting range.
