Inspire & Inspire HR Battery Issue
ANSWERED
Fitbit update: 4/9/19 Our engineers have added the Stats Heavy and Valerie clockfaces back into the gallery. Feel free to re-install them if you had recently removed them due to battery concerns.
Our team was recently made aware of an issue which may be affecting some users battery life while using certain clockfaces on Inspire and Inspire HR. We are currently looking into this and hope to have a fix identified soon.
In the meantime, I recommend switching to one of these three clockfaces: Simple Stats, Shifted, or Analog. After some testing, our team has determined that switching to the above clockfaces should help alleviate potential battery drain.
If you are experiencing short battery life after switching to one of the clockfaces above, I also recommend performing a quick restart and following the troubleshoots listed in this article.
As always, I will be sure to keep you all in the loop as more information becomes available. Feel free to let me know if you have any additional insights or questions. Thanks again!
Want to get more deep sleep? Join the discussion on our Sleep better forum.
475 REPLIES 475
Is there any way to enable the stats heavy clock face? I’ve seen it elsewhere for the inspire HR but the clock face isn’t showing up as a choice for me. Kinda frustrated.
Hi
It used to be there at the clock faces. But it seems that it was removed.
I think this needs to be confirmed.
Have a great day
Sent from Mail for Windows 10
Dang that’s a bummer if that’s true
I removed it when I had it because of battery drain thinking that may extend the battery for 4 days but still no more than 2 days
I've come to the conclusion the Inspire HR is a piece of junk! I'm
contacting the vendor to see if I can return it! It won't sync. The battery
life is a mess and i'm going to need glasses to read the stats! HORRIBLE
product FITBIT! Recall em and start over!!
I feel your frustration, I think all the smart watches will need glasses to read, but I like the size myself as I hate wider ones. An OLED screen would have been better for the sun
If you ignore the battery life, it is very good value for price
Size is perfect and light weight
Accuracy is great
It has very good HR, fitness tracking functions
It has notifications, alarm and timer
Water resistant
Price is much lower than other options while you keep the Samsung brand name
Just charge it every couple of days and you are set
Life is not perfect 😊 but let us get out from it what is mostly suitable for us
All the pluses you stated are exactly why I wanted it and was excited for
it. I don't like the big ones either. Even the Charge felt too big for me.
The Alta HR was perfect but I wanted the swim feature that the Inspire HR
has which is why I purchased it. It's not even syncing right with the app.
There has just been one thing after the other with this one. I've had
Fitbit for YEARS so I know they're good but this one is a fail, at least
for now. AND since I'm an optimist more often than not, I'll give it
another shot based on your response. 😊
I had the same syncing issue, I have to go into the app and manually sometimes sync, but I think this can be resolved with updated firmware.
I balance between good and bad features, today one of my friends told me that the inspire had a better shape to match the hand compared to the Alta which is more straight.
Anyway, give it a try, escalate your software concerns, I am sure we will get the required firmware updates accordingly.
All the best
I charged my Fitbit up on Tuesday night but didn't start using it until Wednesday around 1:30pm. By 10pm, the battery was already at 61%. This is extremely disappointing. I shouldn't have to turn off normal features to get the battery life that is claimed for this Fitbit. I am using one of the clock faces that is recommended. After charging it up to 90% last night, I turned off notifications, sleep wake, and all day sync. I didn't know I'd have to sacrifice advertised features to get the advertised battery life.
I switched to the simple stats and the battery is doing better, even though I love the Valarie face!
I also turned off the screen wake, but sometimes it still turns on all on its own! Or I try to push the button to turn it on and it goes on for a second and poof off.
I switched to Simple Stats from Heavy Stats and I think Simple does a bit better on the battery and I can switch between stats by tapping on the screen.
How are you still able to see heavy stats it’s not even an option for me......... I wish there was some way to still enable it because other than that my inspire HR has exceeded my expectations. Just super annoying that whenever I’m jogging or working out to have to tap through the stats in like of just seeing them all on one screen which would be great for workouts. Someone please help!
Sent from my iPhone
I'm assuming some people had heavy stats as their clock face before they temporarily removed it as an option. They should be bringing those clock faces back eventually.
I have the Heavy Stats face on and don't believe I'm having any problems (not removing it now as it's disappeared from the app and I may not ever get it back!)
If it helps any testers... after 48 hours the battery has only gone from 100% to 81%
I haven't taken it off my wrist or charged it during that time, I track sleep and generally only take it off to charge, typically only for an hour or so when the charge is below 50%.
It is paired with an iPhone XS Max - phone, app and device all on most recent software update.
I only receive Fitbit Notifications (no calls/texts/Appointments - As actually have an Apple Watch on the other wrist!).
I have "all day sync" turned ON permanently, 4 Silent Alarms every day; the standard move reminders but have NOT used any GPS Exercise tracking so far.
I have had the Inspire HR for 6 days (heavy stats face throughout) and purchased it from Currys/PC World in the UK and I average 15/20,000 steps a day so I know it's doing its job.  I can't think of anything else that may be relevant but this device has replaced my Charge3 and I have experience with Alta HR, Charge2, Versa and Ionic and feel that (so far) there is nothing unusual about the use or response from the Inspire.
I hope this helps someone in the know! 🙂
Hi all! Just wanted to check in here.
@Terry-A Thanks for the detailed feedback! Glad to see that your Inspire is working as expected.
@MorgieDee @ToryNiquet21 @delsayed1967   Our engineers have temporarily removed the Heavy Stats and Valerie clockfaces from the gallery as the investigate a technical issue. We are hoping to have both of these clockfaces back in the gallery soon!
In the meantime, I can suggest using one fo these three clockfaces to optimize battery life: Simple Stats, Shifted, or Analog.
@sailorbear510 @Jellybn16 Awesome. Thanks for confirming that switching your clock face helped your battery to perform better.
Thanks again for the detailed reports. I will be sure this feedback is conveyed to our team. Feel free to let me know if you have additional questions.
Hi all
I have just found that when I dropped the reminder to walk from (9am to 9pm) to (9am to 9pm) the battery was draining only 25% per day. I had notifications off, and the no alarms. This means the Inspire battery life can reach 3-4 days this way.
I don’t think the heavy stat was the reason at all, it was a suggestion that I read somewhere.
I think the VIBRATION is the one that drains the power heavily as it does with other devices.
I am not sure if sound is a better battery consumer compared to vibration. If it then may be this can be upgraded to future versions.
I think overall whatever we have and the design that surrounds the hands compared to the HR ALTA is better, with limiting vibrations we are set.
Looking forward to your engineers confirmation.
Matt, I am still getting a maximum of 1.5 to 2 days of battery life and I miss the 4-5 days I had on my AltaHR. Overall, I do like the InspireHR better but the battery life is a drag as now I find myself charging it late every night so it doesn't run out the next day. Is there a chance this will get better/fixed?
  Also, the short, SHORT wire for the charger is quite frustrating. Here again, the FitBit was much more user friendly. I truly want a new FitBit to be better than the one I had before; in some ways this is, and in other ways it's not.
   What's on the horizon re. better battery life and a longer charger? Thanks.
Update on my Inspire
I am getting 4-5 days now on my battery.
1.  Using Valerie watch face
2.  Turned off Screen/Wake but it does turn on when hit at times
3.  Waiting until I get a notification that my battery needs recharged.  I think this is key.
4.  Not using sleep tracker
5.  Using all other features
Update on my Inspire HR (I have always used the Simple Stats clock face) :
After noticing my battery dropping 39% in a day, I charged it to 90% and turned off sleep/wake (it still does it occasionally when I touch the screen), text/app notifications, and all day sync. I don't really miss any of the features I turned off, so it hasn't bothered me any. Since doing that, it's been about 36 hours. In the first 24 hours, it dropped from 90% to 75% which I think is pretty great for an entire day. In the last 12 hours, it's dropped 8%. I would expect it to drop more as the days go on, but if I can get it to last 4 days on a single charge, I'll be happy. Keep in mind my battery wasn't even fully charged. I will see what it's at by the end of today.
I think it's very related to the vibration. Anything that causes vibration consumes battery
I have all on except the alarm, notification and 9am to 3pm once per hour walk alert
Drop will be 25% a day
